Don't say it's the heater core!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tour991, Jan 6, 2020.
  1. Jan 6, 2020 at 12:50 PM
    Tour991
    Tour991 [OP] Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    So my 97 is not blowing hot air now. Just luke worm air if that. I flushed the system this morning. Let the truck heat up to temp then drained it again. The water that I drains was work but not hot. I tested the thermostat. It opens at around 180 ish. I took the hose and flushed out the heater core, that didn't help either. Any ideas?
    Running Board Man and GQ7227 like this.
  2. Jan 6, 2020 at 12:55 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I've heard the term "burping the system" applied here...?
  3. Jan 6, 2020 at 12:58 PM
    Tour991
    James
    South Reno/Tahoe
    Did that also and it didn't help.
  4. Jan 6, 2020 at 1:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm guessing you are low on coolant.
    Any idea on how much you put in?
    Squeeze the radiator hose to push air bubbles out or the system. Leave the cap off and you can see the bubbles .
  5. Jan 6, 2020 at 1:05 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    “It’s the heater core!”
    PennSilverTaco likes this.
  6. Jan 6, 2020 at 1:07 PM
    PennSilverTaco
    Charlie
    If the heater core was bad, wouldn't it be leaking and causing water to pool on the passenger side?
  7. Jan 6, 2020 at 1:10 PM
    Tour991
    James
    South Reno/Tahoe
    That's what I thought to. If I turn the heater off when the trucks wormed up and then turn it on it blows hot for about 5 seconds.
  8. Jan 6, 2020 at 1:10 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Could be a small leak just causing vapors to escape. It may or may not be the issue. I just said it because he said not to say it.
    Any common signs of a bad core op?
    Tour991[OP] likes this.
  9. Jan 6, 2020 at 1:12 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did you try turning the A/C off if it was on?
    maybe its stuck on the defrost
    how many miles do you have?
  10. Jan 6, 2020 at 1:18 PM
    Tour991
    James
    South Reno/Tahoe
    Tryed that also. Truck has about 350,000 and tooend rebuild about 15,000 miles ago.
    GQ7227[QUOTED] likes this.
  11. Jan 6, 2020 at 1:54 PM
    Tour991
    James
    South Reno/Tahoe
    Any one know what a full fill would be? How much coolant? It seems like I'm getting about a gallon and maybe squirt of watter in the system. Also my coolant line into the heater core is hot but not the line out.
  12. Jan 6, 2020 at 1:57 PM
    Wulf
    rock raisin
    Sounds like the heater core is clogged. Do you have access to a compressor?
    something like this should be able to push blockages out better than just trying to use a hose alone https://www.amazon.com/OTC-6043-Blast-Vac-Multipurpose-Cleaning/dp/B000F5ECRW
    xxTacocaTxx and tcjacado like this.
  13. Jan 6, 2020 at 1:57 PM
    tcjacado
    tcjacado Well-Known Member
    Heater core could be plugged up with debris.
  14. Jan 6, 2020 at 2:02 PM
    Tour991
    James
    South Reno/Tahoe
  15. Jan 6, 2020 at 2:13 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Did you check if the blend door is working properly? The heater hose valves and cables?
  16. Jan 6, 2020 at 2:16 PM
    Tour991
    James
    South Reno/Tahoe
    Yeah it's working. I tested that also.
  17. Jan 6, 2020 at 2:20 PM
    Tour991
    James
    South Reno/Tahoe
    So I don't think it's clogged
  18. Jan 6, 2020 at 2:39 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    So a little more detail please. Is the air warm all the time or just when fan on high at idle?
    I have come to the conclusion that the heater core doesn't have the capacity to throw out HOT air when the ambient temp outside is like 20 degree or below and at idle and in gear (AT at 500 RPM). As soon as RPM's go up to about 1000 RPM it will blow hot. Now it sounds like you've checked the 99% of the typical issues dealing with this - thermostat, air in system, back flushed heater core, etc. The water pump has steel blades and so that's not it unless they are damaged or it's not spinning. The next thing I would do is the CLR flush for 1/2 hour. Only put that stuff in the core and flush out before sealing up the system again. It's a last resort but it does work most of the time if you have a corroded heater core. Be careful using the pressure of a garden hose or compressed air. The core is only designed for 15 psi and you could blow it out of you put more pressure in.
  19. Jan 6, 2020 at 2:57 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    When you were flushing the core did you have good flow coming out the opposite pipe/end? If flow was great, could you tell no obstructions in the core? Mmmm
  20. Jan 6, 2020 at 3:02 PM
    Tour991
    James
    South Reno/Tahoe
    Thanks everyone. I got it fixed. Not sure 100% what the issue was but I after flushing the core, changing the thermostat and radiator cap, flushing the radiator and block, burping it and almost 2 gallons of fresh coolant she is blowing hot.
    xxTacocaTxx, tcjacado and cruiserguy like this.
