Donut in Transmission - Vibration Dampener? - Rubber Seal? What is it??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cire, Mar 21, 2016.
  1. Mar 21, 2016 at 9:25 AM
    MKMotorsport
    MKMotorsport Well-Known Member
    AZ
    '15 DCSB TRD/OR
    All-Pro skid'd, UGMx1.3, 7pin delete via rock
    ^^This.
    Keep in mind driveshafts are balanced as an assembly. That could be why yours is vibing- if it had one and is now gone. however! re-installing a random one would probably be wrong too, as it would need to be installed, then the entire driveshaft assembly with new part re-balanced, if you were interested in "doing it right"
    Agreed though, does not appear to be a giubo. Apologize for that miscue. The above though certainly applies.
  2. Mar 21, 2016 at 9:27 AM
    Cire
    Cire [OP] Well-Known Member
    Eric
    Tucson, AZ
    2006 Toyota Tacoma Prerunner Regular Cab
    Stock
    Here is the video of it. = )
    Eric
  3. Mar 21, 2016 at 9:30 AM
    Cire
    Eric
    Tucson, AZ
    Stock
    Hey, no worries on the miscue. = ) Any insight, wrong right or indifferent, help fuel ideas on what it could be. I just appreciate someone else's insight. So kudos and thanks!!!
    As for doing it right, you are right... If its really a pressed on item, then chances are very high its balanced with it on.... Therefore it being missing could cause an UNBALANCE which might drive the small vibration I feel. And doing it right, is removing it, taking it to the drive shaft guys and having them balance it AS IT SITS NOW...
    = ) I will get on it and give you feedback. = )
    Thanks again everyone
    Eric
  4. Mar 21, 2016 at 9:32 AM
    1MK
    1MK Desert Explorer
    Southern California
    Due to the yoke having floating splines to allow movement, it's naturally going to have play.
  5. Mar 21, 2016 at 9:33 AM
    Cire
    Eric
    Tucson, AZ
    Stock
    Did some Tacomas not come with a dust cover shield thing?.... When I took it off to get the U-Joints done it didn't have one then either.
    If some didn't come with them, could the drive shaft be balanced and not need to be rebalanced?
    Hmmmmmm
  6. Mar 21, 2016 at 9:34 AM
    Cire
    Eric
    Tucson, AZ
    Stock
    I think its only $30 or $40 bucks to balance the drive shaft if I take it off, take it to the guy and leave it with him for a few days.... Humph!!!
  7. Mar 21, 2016 at 12:27 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it is a propshaft damper useful when overdriving the propellor and reducing 'funny noise' complaints from owners
  8. Mar 21, 2016 at 5:21 PM
    Cire
    Eric
    Tucson, AZ
    Stock
    I looked it up on the internet and it looks more like a carrier bearing or a center bearing or something other than the o-ring thing I need. But I will see if I can find more on it. Thanks.
    Eric
