Door arm rests
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HealeyBruce, Oct 4, 2020.
  1. Oct 4, 2020 at 7:32 PM
    HealeyBruce
    HealeyBruce [OP] Member
    Bruce
    2006 PreRunner SR5 Double Cab Long Bed
    I just picked up a 2006 PreRunner SR5 Dual Cab Long Bed that I'm now in the process of fixing up. The front door arm rests have cracked under the fabric. I'm finding plenty of vinyl replacement kits on eBay, but they're only the cover, not the underlying structure. Anyone either a) have a source for the actual armrest piece, or b) have repaired them? I was thinking about using an epoxy putty like PC11 to repair the cracked substrate from the under side, or possibly use the PC11 to secure some underlayment to reinforce the arm rest.
  2. Oct 4, 2020 at 8:02 PM
    DR_CA68
    DR_CA68 Well-Known Member
    Dean
    San Jose
    08 TRD SPORT SHORTBED DC
    trying to keep stock
  3. Oct 4, 2020 at 8:14 PM
    Muddinfun
    Muddinfun Well-Known Member
  4. Oct 4, 2020 at 8:40 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Unfortunately, if I'm not mistaken, the substrate is polyethylene or polypropylene and there's not much that will stick to it, long term. You could give it a shot but I don't think it would hold up.
    I hate to sound like a wet blanket but you'd have better luck with a mechanical support of some type, like a thin plate of steel riveted to it.
  5. Oct 4, 2020 at 9:05 PM
    HealeyBruce
    Bruce
    Thanks for the links and info. Looks like there's a ton of helpful info on this site!
    Muddinfun likes this.
  6. Oct 5, 2020 at 5:14 AM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    I used fiberglass and it's so strong I can put my whole weight on the armrest.
