Door Bouncing Back in 2013 Tacoma I4 Access Cab
Discussion in 'New Members' started by Dayton2012, Nov 23, 2012.
  1. Nov 23, 2012 at 7:02 AM
    Dayton2012
    Dayton2012 [OP] New Member
    Dayton, OH
    SR6
    Just bought the 2013 Tacoma Access CAB and noticed that I had to close the door harder (basically slam it) to get it closed. Have taken it to the dealership and they tried realigning the door by bending/twisting (gently) and that did not solve the problem. I checked with few other newer access cabs and I felt the same with other cabs. Tech guy told me that there is a vent for releasing pressure when you close the door, but for this 2013 truck, there is only one vent in the middle and that may be too small. According to him, in certain models, they have two of those vents.
    I was just wondering whether any of you guys have the same experience with any 2013 models. This is my first truck and I believe the doors are bit rough compared to a sedan but I certainly have to put a bit of pressure to close it completely. Appreciate very much if you can share your experience.
  2. Nov 23, 2012 at 7:14 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I do agree that you have to put a little more muscle into shutting the door but thats the way all of the 2nd gens are. It took me awhile to get used to it versus my 1st gen.
  3. Nov 23, 2012 at 7:19 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Is it a vent in the weatherstrip bulb or vent in the cab he's talking about?
  4. Nov 23, 2012 at 7:20 AM
    MTBerJim
    MTBerJim You Know We Can't Do This All Day!!!
    Long Island, NY.
    2012 Tacoma 2.7, Auto, 4x4
    Original
    I have to pull my door pretty hard also (harder than I had to with my F-150 extended cab). When I have the guys from work in it they almost never get the door closed tight on the first try.
  5. Nov 26, 2012 at 10:04 AM
    Dayton2012
    Dayton, OH
    SR6
    FileIFR:
    The vent is in the middle of the cab behind the back seat and it opens up to the space between the cab and the truck bed. Even if I lower the glass and try to close it, I had to sort of slam it hard. My neighbor has a Chevy Silverado and he thinks the door should be adjusted.
    Thanks for all your inputs.
