Door check stop needs replacing
Discussion in '1st Gen. Tacomas (1995-2004)' started by notslow, May 18, 2009.
  1. May 18, 2009 at 5:30 PM
    notslow
    notslow [OP] Well-Known Member
    Palm Springs, Ca.
    02 TRD black
    Hi Guys,
    So my driver's side door won't stay open. I finally got around to taking the door check thingy out and it is all bent and worn out. The previous owner must have been really rough swinging the door open. Anybody know the best place to get one? How much they run?
    Will
  2. May 31, 2009 at 10:14 AM
    notslow
    Palm Springs, Ca.
    02 TRD black
    In case anyone else needs to know. The part number for the driver's side is [FONT=&quot]68620-04010 and it cost around 70.00 :eek:.
    I am hoping I can find a used one, but it's almost impossible to find a tacoma being parted out.
    Will
    [/FONT]
    2003Squirrel likes this.
  3. Jun 1, 2009 at 6:35 AM
    ViperR
    ViperR Active Member
    NC
    bare-bones
    I'd still hit a bone yard. There are lots of toyotas that use the same parts in various models close to your year. I did this with my '95.5 Taco and used alot of parts from Camrys, Celicas, Corrolas, etc.
  4. Jun 1, 2009 at 11:17 AM
    notslow
    Palm Springs, Ca.
    02 TRD black
    I'll check it out online and see if any of them show the same part. If so, I'll know what to look for.
    Thanks, Will
  5. Jun 9, 2009 at 1:30 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Okay, I checked out some other toyotas. They all seem to have the same part of the door check that wears out the part that is inside the door that the metal arm slides in), the arm and bracket that mount to the jam are different though. I got one off of a Camry and cut the pin that holds the assembly together and switched the arm. Put a new roll pin in place of the pin I cut off and it's as good as new. If anyone else needs help with this feel free to message me.
    Regards, Will
  6. Apr 12, 2013 at 4:01 AM
    ezatnova
    ezatnova Artax
    West Chester, PA
    11 DC TRD OR
    Hankook Dynapro 265/75/16, Icon Progressive AAL, 5100's @ 1.75, derped badges
    I realize this thread is old, but it's the only related one I can find.
    My checks (especially driver) are worn out too. Very annoying, as the door won't even stay open on flat ground. Before spending $140, I figured I'd try a free fix. I put two part epoxy on the two "bumps" of the check, to try and build it back up. Crossing my fingers that it will work, but I have my doubts. I wasn't about to install it back in last night and risk epoxying my door shut :eek: so I'll mess with it tonight. I'll report back as to whether it seemed to work or not. I can't be the only one with this issue, given the age of these trucks now.
  7. Apr 15, 2013 at 8:24 PM
    skeezix
    skeezix The Voice of Experience (mostly negative)
    Colorado
    1998 Limited
    Did it work?? :popcorn:
  8. Apr 15, 2013 at 11:13 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    coupla' options
    Used
    New/oem Aft. Mkt.
    read that driver and passenger are the same #, 95-04
    if that's correct..? swap the catch of each door
    and maybe warn the passenger :p
  9. Apr 16, 2013 at 5:03 AM
    ezatnova
    ezatnova Artax
    West Chester, PA
    11 DC TRD OR
    Well, the first epoxy fix was a failure. It was clear two part epoxy. After it dried, the first time I tried the mechnism, it sheered the epoxy right off the plastic of the check. I then tried a "JB weld" type of epoxy. Let this dry for a couple of days. It was then too much build up for the mechanism to be able to clear the new humps, so I ground them down a bit. It now seems to work decently. If I was operating at 5% before, I'd say it now works at 60-75% of what a new one would. Hopefully it holds up well. I took out the passenger side and applied the JB weld last night, so I'll probably have to grind it a bit tonight.
    As far as the R and L being identical.... I can't attest to that, but I do know that they are stamped "R" and "L".
  10. May 21, 2013 at 9:54 PM
    Shawster
    Shawster Member
    Hey guys,
    Mine are both worn as well. Before I dive in on this, what is involved to remove them? Do you need to remove the interior door panel or can you access everything from the jamb?
  11. May 22, 2013 at 3:44 AM
    ezatnova
    ezatnova Artax
    West Chester, PA
    11 DC TRD OR
    It's easy..takes 5 minutes (maybe 10 the first time if you've never taken the door panel off).
    Take off door panel
    Take off plastic covers on the door check...one from inside door jam/hinge (this is what covers the two nuts...10mm I think) and one on the larger bolt on the body side.
    Remove the two nuts and one bolt
    Slide it out through the open door area where the panel was.
  12. Jul 3, 2014 at 2:49 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    I just called local dealer for a price. $103, anal lube not included. Getting online hits for ~$70.
  13. Jul 3, 2014 at 9:23 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    I have two of them for first gen.
  14. Jul 4, 2014 at 2:56 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    And...?
  15. Jul 4, 2014 at 7:57 PM
    Andy.G
    Andy
    Virginia
    25.00 each plus 5.00 shipping.
  16. Jul 4, 2014 at 11:55 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Are they new or used?
  17. Jul 5, 2014 at 1:40 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    When I'm done it will have a custom fabbed winch bumper and hopefully a Softtopper.
    Andy's are used.
    I have a passenger door side one. Mine is used as well.
    Same price if anyone is interested.
    Later
    KO
  18. Jul 5, 2014 at 7:44 AM
    Andy.G
    Andy
    Virginia
    Thanks Kirk for filling in the line for me. I got to remember to be more specific.haha
  19. Jul 5, 2014 at 9:08 AM
    Yarddog
    Yarddog Member
    Vance
    Santa Clarita, CA
    Prerunner TRD Off-Road
    When using epoxy or JB Weld, it's a good idea to not only thoroughly clean the area being epoxied, but also give the area some 'tooth' by sanding with coarse grit sandpaper or a grinder of some sort...for smaller pieces, I use a Dremel tool with a cut-off blade to run over the surface...if you don't give the surface some tooth, of course the adhesive will fail. A little tip here for y'all...
  20. Sep 29, 2014 at 8:40 AM
    carma
    carma New Member
    I am looking for a door check for a 2009 Tacoma - driver's side. thanks.
