Door chime - Always on with door open
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco_Love, May 2, 2024.
  1. May 2, 2024 at 8:32 PM
    Taco_Love
    Taco_Love [OP] Well-Known Member
    99 reg cab 4x4
    Hi All,
    I have a weird problem, searched all the forums but haven't found a post that matches my issue exactly. Since I bought this truck, the door chime will go off as long as the truck is hooked up to the battery and the drivers side door is open. This happens whether a key is in the ignition or not.
    From my understanding, the door chime should only go off if the key is in the ignition and either turned to the acc or the on position. I was wondering if anyone might know what would be causing this and how I could fix it?
  2. May 2, 2024 at 9:07 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Take off the plunger looking switch off driver side (B pillar) and inspect
    or just press….see if you hear a click or if feels crunchy when you press
    Switch should be surrounded by a rubber accordion looking cover
  3. May 2, 2024 at 9:18 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  4. May 2, 2024 at 9:28 PM
    Taco_Love
    99 reg cab 4x4
    Hmmm, that is interesting. One of the things that I replaced when I got the truck was the ignition cylinder. The previous owner had rigged up some ignition that could be turned with pretty much any key, and you could also take the key out in any position.... Wonder if he mangled something in there.
  5. May 2, 2024 at 10:00 PM
    O'Silver_Taco
    MD
    The switch is held on by two screws under the cylinder....
    and they do go bad in different ways...
    this one use to be mine........it started popping the am2 fuse when you accelerated at weird times...
    Ign movie (youtube.com)
    Really the cylinder and switch should be replaced every 150K....
    after that.....they can send you walking.....
    If you wait too late on the cylinder and cant key it to accessory.....then you have to drill it out.........number vids out there with the O' drill....
    That switch is so important I keep a spare used one off a corrolla my glove box...
    Replace ignition switch 95-2000 Toyota Tacoma : Andy’s DIY (youtube.com)
