Door Chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MDBigRed, Jan 1, 2010.
  1. Jan 1, 2010 at 11:01 AM
    MDBigRed
    MDBigRed [OP] Well-Known Member
    Potomac, MD
    '08 TRD Sport 4x4
    Uniden PC78Elite CB, 4' Firestiks, KC reverse/work lights, Mudflaps removed, Gorilla wheel locks, TRD box air intake, MBRP XP series dual exhaust, Wet Okole seat covers, 20% front tints, Pacer tailgate light bar, Uniden Bear Cat PA external speaker, 4.5" RCD Lift w/ extended ICON coilovers, door sill LED running lights, LED alarm scanner light, Scangauge II, Blendmount, Diff breather mod, Whelen hideaway 90watt strobes, Piaa Xtreme white bulbs, VIAIR onboard air, Allpro T-case sheild, TC LCA Skids, Stubbswelding HD-SKO Sliders, Weathertech floor mats, TC UCA's, Allpro SS brakelines, rear ARB locker, 4.56 Yukon gears, BlueSea fuse block, bed rail light bar, Shrockworks bumper, Smittybuilt XRC8 Comp winch, IPF 900's, Piaa 510's, Tekonsha brake controller, Air horn, Pop 'n lock, Alcan Spring leaf packs, JVC KD-AHD 69 head unit, 12voltguy winch controller, Safari Snorkel
    So i've searched around to try and find the way to disable the door chime when the key is in the ignition. I frequently open my doors and use the stereo to play music outside, so it gets REALLY annoying. Any suggestions???
  2. Jan 1, 2010 at 11:03 AM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    pull the dash out and snap off the buzzer off of the back
    there was a write up posted recently...
  3. Jan 1, 2010 at 5:44 PM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    Ok thanks I'll check it out:)
  4. Jan 1, 2010 at 7:00 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    turn key to on position?
  5. Jan 1, 2010 at 7:10 PM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    true, but then all of the gauges light up and come on which use up my precious battery juice :)
  6. Jan 1, 2010 at 7:13 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    if people hear the chime with door open while playing music then you probably arent playing the music loud enough
  7. Jan 1, 2010 at 7:14 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    :D werd
  8. Jan 1, 2010 at 7:15 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    turn the lights off with the little dial on the left side of the dash then.
  9. Jan 1, 2010 at 7:30 PM
    wwjdweldingman
    wwjdweldingman Member
    sourthern cali
    2wd 05 Prerunner SR5 w/ LSD
    double din dvd system. tinted windows, billet grill, AFE intake, HIDs 8000K high/low, black headlight mod.
    yea, when i did my light guage mod, the door chimes soldered into the computer board, in 2 spots and i just headed it up with a soldering iron and it came right off!!! NO more annyoing chime :)
  10. Jan 1, 2010 at 8:24 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I've thought about just running a little switch to the door sensors to be an over-ride.
