Door control
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buzzout, Apr 24, 2025.
  1. Apr 24, 2025 at 2:33 PM
    Buzzout
    Buzzout [OP] New Member
    96’ Tacoma king cab 4x4 2.7
    Does anyone have a work around for a 96’ Tacoma door control
    85980-35050? I can’t find any online except for a $350 door control. I was thinking another Toyota from the same year that has two door, power locks and windows might have the same module.
  2. Apr 25, 2025 at 5:53 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Welcome aboard, do you mean the window switch in the door, door lock mechanism? I did a quick search on autoparts.toyota.com and that number doesn't give me anything, related results brings up other equipment, none of them for Tacomas.
    I would start digging around eBay once you have a correct number. When I bought mine the power window switch was toast and found one for a Camry that fit so you're close to correct. When it comes to electric body parts, often the parts from other same year or close year Toyotas will fit and they're often significantly cheaper than a specific Tacoma part.
