Door gasket care?
Discussion in 'Detailing' started by ssanders2211, Jun 13, 2014.
  1. Jun 13, 2014 at 7:33 AM
    ssanders2211
    ssanders2211 [OP] Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    I know they'll wear out eventually, but what can I do to maximize their lifespan? So far I've just been cleaning them off with 303 Aerospace after I'm finished with all my other plastic trim. Should I be using a silicone lubricant instead?
  2. Jun 13, 2014 at 7:42 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    I say just keep cleaning them off. I use turtle wax ice detail spray and clean the whole door jam area. make sure what you use is safe to use on rubber.
  3. Jun 13, 2014 at 7:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    303 is good stuff. They should last longer than the truck will.
  4. Jun 13, 2014 at 8:08 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    X2. I put 303 on everything.
    Probably if you completely ignored the door rubber it would last just as long. Actually, the pulling pressure involved in cleaning them probably does more damage then good in breaking them free from the door over time?
    I just can't stand to see them all gunked up and dirty.
  5. Jun 13, 2014 at 8:11 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    try fluid film, works good for everything else.
  6. Jun 13, 2014 at 9:31 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Wipe down and 303. Can't add anything that hasn't already been said...
  7. Jun 13, 2014 at 5:42 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    X4, has worked well on all my car's gaskets over the years.
