Door handle death
Discussion in '1st Gen. Tacomas (1995-2004)' started by sandybeech, Sep 21, 2020.
  1. Sep 21, 2020 at 1:22 PM
    sandybeech
    sandybeech [OP] Member
    '99 Tacoma
    So, my passenger side door handle died. I can open it from the inside no problem.
    It became a problem though when my driver side stopped working from the outside too! I had it fixed at a garage. They charged me $225.36 for parts, and $420.00 for labor, for a whopping total of $645.36! This was February last year (2019), and the door handle just frigging broke as I was pulling on it to open the door. It always felt a little fragile to be honest, I could feel it twisting and straining before it engaged the latch and never felt solid.
    So, I brought it back to the same garage. Should they fix it for free on the labor or something? This just seems like shotty work.
    Attached is the the original fix invoice with a description of the labor:
  2. Sep 21, 2020 at 1:27 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  3. Sep 21, 2020 at 1:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Sep 21, 2020 at 1:37 PM
    sandybeech
    '99 Tacoma
    cool, thanks. I'll try doing the passenger side one on my own!
    Let me know if you have thoughts on the driver's side. Since I spent so much money on it last year, I want to see if they'll give me a break on fixing it. Maybe just charge for parts or something. I'm waiting on AAA right now since both door handles are broken. I won't have time of my own this week to fix it either and I need to be able to use it soon before I could get to it for one of the handles...
    Interesting though that they had to remove my car seat to do this when the youtube videos you don't
  5. Sep 21, 2020 at 1:42 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That shop has no business charging basically 4 hours labor. I wouldn't associate with them ever again if it were me, but if you want to see if their work comes with a warranty then you could call and ask.
    ThunderOne likes this.
  6. Sep 21, 2020 at 1:44 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Door handles are easy peasy, take it from me...I'm not a mechanic by any means and I've broken/replaced a half dozen of them.
    That shop robbed you, sorry to say...it's a 30 minute job at most once you know how it's done. OEM handles are expensive but the aftermarket ones can be had for $20 and work just fine.
    Get some replacement door panel clips because they do break easily when you pop the inner door panel off. The video @Dalandser posted is a good one to go by
    Hamer95USA and Dalandser like this.
  7. Sep 21, 2020 at 1:47 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My gawd, I’ll do it for 1/3 the cost. You provide the part.
  8. Sep 21, 2020 at 1:47 PM
    eon_blue
    Azusa, CA
    I've broken mostly OEM handles, I've had good luck with the cheap Dorman ones or the T/A ones from Amazon.
    The handle design in general just lends itself to being fragile after a certain number of years/miles/being abused. My last one broke after a weekend of my 7 year old nephew going in/out my truck on the passenger side while we were camping.
    Dalandser likes this.
  9. Sep 21, 2020 at 1:58 PM
    eon_blue
    Azusa, CA
    happens to the best of us, the first time I needed a CV axle replaced I provided the axle and the shop still charged me $400 for it, lol. For one side.
    That was what convinced me to do it myself after that and thank god I did, cause I've replaced probably a half dozen by now.
  10. Sep 21, 2020 at 2:06 PM
    JKO1998
    Utah
    Shop prices have forced me to learn a lot haha
  11. Sep 21, 2020 at 2:10 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Yeah, it makes no sense that they said that they removed your seat to fix a door handle.
  12. Sep 21, 2020 at 2:13 PM
    eon_blue
    Azusa, CA
    I just saw this part, if the handle was twisting when being opened then that means they did not clip it into place when they installed it. The handle sort of snaps/clips into place when it's perfectly aligned and installed, if that step isn't done then it will have some play to it. They definitely messed up
  13. Sep 21, 2020 at 4:49 PM
    sandybeech
    '99 Tacoma
    That's exactly what happened!
    btw, here is my door...just fyi
  14. Sep 21, 2020 at 6:11 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    jesus CHRIST 600 dollars in labor?!
    mate I would run a smear campaign on that shop.
  15. Jan 1, 2021 at 8:22 AM
    TACO in SC
    TACO in SC TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
    This tread discusses the exterior door handles and how they break. I've changed mine out a few times.
    A few months ago the passenger side broke and I found the T1A metal handles. They are solid. The handle seems to be cast aluminum while the frame is plastic. I replaced the passenger side but will wait for the driver's side to break before replacing it. The passenger door opens very solidly with no felt flex of the handle.
    This is what I bought, but now they say out of stock. They are probably found elsewhere.
    https://www.amazon.com/gp/product/B07YQBPHS9/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    Here is one for the passenger side. They now seem difficult to find.
    https://www.amazon.com/T1A-Passenge...al+Upgrade&qid=1609518233&s=automotive&sr=1-1
    It seems T1A also sells plastic versions of the same so make sure you select the Metal Upgrade option.
    Hopefully I will never again have to replace them.
    Matermax likes this.
  16. Jan 1, 2021 at 9:17 PM
    Matermax
    Matermax Well-Known Member
    Nathan
    NE Arizona
    1999 Tacoma TRD
    White Line LCA bushings.
    These are the ones I used just last month, they seem pretty solid
  17. Jan 1, 2021 at 10:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    So I'm kind of digging this one up but did anyone read the work order? they list a new door latch along with the handle.
    When door latches fail they stick closed, like completely closed, not responding at either inside or outside handle. Id be willing to bet that's what happened here. You have to remove the door panel frim the inside (with the door still closed) and get inside the door to release the latch.
    Thats not easy! The seat is in the way, the steering wheel is in the way, you're crawling across the car from the other side. He specifically mentions having to remove the driver seat and manually force the latch off the striker to get the door open. A lot more involved than just "throwing a new door handle in it"
  18. Jan 2, 2021 at 8:22 AM
    TACO in SC
    TACO in SC TuRD
    Andrew
    Greenwood, SC
    Pretty well stock
    I wanted to communicate the nice door handles I found and instead of starting a new thread I picked this one after doing a search. Perhaps I should have just started a new thread, but I meant no harm. I agree the OP had a greater problem then just the broken exterior door handle.
    I think I'll go ahead and swap out my driver's side latch. The plastic one will fail, just don't know when and it might be sometime that it's real inconvenient to me.
    Steves104x4 likes this.
