Door handle issues- I'm at a loss
Discussion in '1st Gen. Tacomas (1995-2004)' started by La_Mere, Jul 12, 2025.
  1. Jul 12, 2025 at 8:33 PM
    La_Mere
    La_Mere [OP] Active Member
    Christopher
    Arizona
    2000 Tacoma 3.4L 5-speed 4x4
    Evening, everyone! So my driver's side door handle will not open the door unless I pull the full travel of it. (Out as far as it will go.) I have had the handle out several times, but I can't see anything wrong with it or the linkage inside. From what is visible, at least.
    Both handles were replaced with a non-oe unit under prior ownership, but the passenger side works fine.
    Thanks everyone!
  2. Jul 13, 2025 at 8:21 AM
    ChinoXL
    ChinoXL Well-Known Member
    95 Tacoma V6 MT 4x4 Xtracab
    Mine does the same. I have the Amazon “upgraded” T1A metal driver door handle and it still makes me worry that the handle will stop functioning like the original and its plastic replacement did.
    I hit the latch mechanism with some white lithium grease and that seemed to help a little.
  3. Jul 13, 2025 at 9:31 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It’s probably the latch worn out not the release handle.
  4. Jul 13, 2025 at 10:25 AM
    foresterfields40
    foresterfields40 Well-Known Member
    ‘99 Tacoma 3.4 4x4
    Likely one of the rods has straightened out a little. You can use a pair of pliers and put a little more bend to one of the existing bends in the rod. That’ll shorten the length enough to prevent having to pull the handle all the way up
