Door handle loose
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomanc910, Apr 21, 2013.
  1. Apr 21, 2013 at 7:21 PM
    Tacomanc910
    Tacomanc910 [OP] Well-Known Member
    Tyler
    NC
    00 Tacoma SR5
    For my driver and passenger side doors the door handles are not working till you have to pull them hard. Is there a screw missing? Is it not triggering at a certain point? Thanks!
  2. Apr 21, 2013 at 9:48 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    remove the interior door panel and look for yourself.
    It's not hard... there's like only two screws that hold the handle.
    It's most likely some issue with the linkage rod ends
  3. Apr 22, 2013 at 6:30 AM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    Be careful if you remove it it is very easy to bend the slotted portion of the latch rod causing you hrs of aggravation trying to realign it to get the lock of handle to work again
