Door handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by mwrohde, Jan 26, 2016.
  1. Jan 26, 2016 at 11:59 AM
    mwrohde
    mwrohde [OP] Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    The driver's door outside handle broke on my truck the day I bought it. I made the dealer I bought it from buy me a new one. Two years later and now that one is on the verge of breaking, too.
    Does anyone have a source for another new outside door handle that might last longer than a couple of years?
    Thanks,
    eudaimonx likes this.
  2. Jan 26, 2016 at 12:18 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Toyota door handles are 95% plastic and are prone to breaking over time. I've replaced many of them, using handles obtained from the local PicknPull. They should last longer than that, though. Be gentler when you pull on it :D.
    Your door hardware might be sticking for some reason, requiring more opening force on the handle. Take the door apart and find out why its sticking. Maybe just lubing all the friction points will help.
  3. Jan 26, 2016 at 1:00 PM
    mwrohde
    Sugar Hill, GA
    When I get a new handle I'll look at the internals. It's hard to see anything in there, though.
    The inside handle doesn't feel stiff, though. I'd think if something were sticking I'd feel it inside, too. yea?
  4. Jan 26, 2016 at 1:42 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Just got a drivers side handle for my double cab. Got tired of opening the front door by reaching in through the back door. $40 from rock auto. Made by doorman. I'll install it in the next couple days.
  5. Jan 26, 2016 at 2:16 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Lucky you had the double cab and could wait. Mine gave out yesterday on my extra cab to the point that I had to crawl in from the passenger side. The Dorman replacement was $79.95 at O'Reilly.
  6. Jan 26, 2016 at 3:17 PM
    tan4x4
    Rick
    Folsom, CA
    At my local Pick-n-pull, outside door handles are $12 each. May not be the right color, though. I had to wait until a truck of the right color showed up. Plus, I got to practice removing one on a wrecked truck :D .
  7. Jan 26, 2016 at 7:35 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    most are black, unless you want a color-matched (red, silver, black, green)
  8. Jan 27, 2016 at 5:32 AM
    mwrohde
    Sugar Hill, GA
    First, there'd have to be a Tacoma in a yard. I haven't seen one. Ever.
    You can open it from outside without a handle with a pair of pliers. It's a different sort of suck, but maybe better than crawling over from the passenger side.
  9. Feb 20, 2016 at 9:47 AM
    jrf89
    jrf89 Member
    1999 Tacoma EC 4x4 2.7L 5 speed SR5
    So this will be the third time replacing my driver's side handle in the 6 yrs ive had my truck....these plastic ones just dont hold up to the montana winters. Any suggestions on a sturdier handle? Maybe even one made out of metal? I'm getting really tired of replacing them.
  10. Feb 20, 2016 at 9:02 PM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    I used the el cheapo Dorman ones on both sides about a year ago. So far, holding up.
    The 3rd door handle on my 99 s-10 broke, apparently it was an ongoing problem with s-10's. I found an aluminum one for like $25. I was surprised to not be able to find something similar for my Tacoma.
  11. Feb 20, 2016 at 9:05 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    If anyone finds links to metal handles let me know.
  12. Feb 20, 2016 at 9:07 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Both my door handles broke
    Paid 10$ each for brand new ones and they work great
  13. Feb 20, 2016 at 9:36 PM
    jrf89
    jrf89 Member
    I've been using the $12 ones off Amazon and at -15 degrees or lower they just snap. Aluminum handles would be amazing but after hours of online searching i've come up with nill. I did find a dorman handle that claims a limited lifetime warranty for about $30, anyone ever broken one and dealt with dorman's warranty department?
  14. Feb 21, 2016 at 2:24 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Nope. They're all pretty much low quality. Unless you go oem. Biggest thing here is to keep the latch mechanism lubed and free of dirt/grime. I've gone through a couple sets now, and the last time I sprayed a crap ton of penetrating lube all inside the latch from the outside, as well as the inside. Which the inside has another sliding mechanism for the rod, that is tucked behind (the side window guide iirc, in the area were the latch is) and can be got to by feeling and fishing your straw in from the inside, and spraying that too, and cycling the latch multiple times to clean and lube it fully. Since then mine have been popping open very easily for quite some time now. Just go to town with the lube. Not gonna hurt anything. Just keep a rag handy and wipe up any drips/runs.
  15. Feb 21, 2016 at 3:05 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have pair of chrome take offs from my old '98.
  16. Feb 21, 2016 at 6:43 AM
    anthony250f
    Anthony
    San Diego, CA
    I buy the 10$ ones off eBay. Cheap enough to just replace yearly when they break lol
  17. Feb 21, 2016 at 11:06 AM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    Mine almost broke completely off one day. Dried it off and cleaned it up good and applied jb weld to the crack. So far so good!
  18. Feb 23, 2016 at 12:11 PM
    TacomArizona
    TacomArizona Well-Known Member
    15' ACOR 2wd 4.0
    You put the JB Weld on recently or has it been awhile?
  19. Feb 23, 2016 at 12:14 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Be sure to lube the new one--they will last longer. Had the same problem--lubing helps!
    TacomArizona likes this.
  20. Feb 23, 2016 at 3:02 PM
    Mikeybuck
    SW WA
    2018, 2010, Tacoma
    Was a couple months ago.
    TacomArizona[QUOTED] likes this.
