Door Handles keep breaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lettusbee67, Dec 8, 2016.
  1. Dec 8, 2016 at 6:14 PM
    Lettusbee67
    Lettusbee67 [OP] Member
    What is up with these door handles? I have a 2004 double cab, and have replaced each exterior door handle at least once. Now the drivers door handle has broken again. I've been buying the cheapo Amazon handles. Will the toyota handles last longer, or is the problem actually in the door mechanism itself?
  2. Dec 8, 2016 at 6:35 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Do they feel sticky when you open them? How does your key feel when you manually unlock? Could be dirty inside. You're right about the quality of door handles. Oem will cost more but they are also more resilient
    jarshie likes this.
  3. Dec 8, 2016 at 7:03 PM
    Lettusbee67
    They don't feel sticky so much as it feels like they aren't doing anything. You can lift em up, but they don't engage the mechanism until the last 10% of travel. And then you really have to pull up to get them to open the door. I was just wondering if there was a common problem with the internals, or if it's in the handle itself. May just have to investigate this weekend.
    vodkapuddle likes this.
  4. Dec 8, 2016 at 7:06 PM
    Maestro
    Maestro Well-Known Member
    The Master
    I had the same problem until I bought the Toyota originals. Went through several. Next time you replace, lubricant all interior contact points before you close things up. You'll be fine afterward.
    jarshie, beez and arifleman like this.
  5. Dec 8, 2016 at 11:19 PM
    lonelywanderer
    lonelywanderer Well-Known Member
    Oahu, Hawaii
    04 double cab 4wd
    Suppose to be stock
    Buy the genuine handles, my friends sister always breaks the aftermarket ones
    arifleman likes this.
  6. Dec 9, 2016 at 6:03 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Anyone know a place where you can get OEM handles where they're not $80 each?
  7. Dec 9, 2016 at 7:21 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Cheapest I could find was around that 80 buck price as well.
    https://www.amazon.com/gp/aw/d/B004...s_1?ie=UTF8&psc=1&refRID=3MNCT52TEJAZVAGH7JDE
    I think I'd try this one for 10 bucks before plopping down 80. Has decent reviews and I'd make sure to apply white lithium grease to all moving parts and contact points within the door upon install. You know, the rods and levers and that stuff.
  8. Dec 9, 2016 at 7:35 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah like already mentioned the cheap ones are just that.....and if you havent definitely lube that stuff in the door! I was recently having a bit of trouble opening the doors on one of my trucks, felt like i was gunna break something eventually and it wouldn't pop open till about the last 10% like you said. I finally squirted some penetrating lube behind the handle anywhere i could and let some run down the side of the interior lock tab. After a day of the oil leaching around on that stuff everything was so so much smoother and easier and the doors pop open quite nicley now, atleast for a while. Would be better to use a real lube after the penetrating oil does its thing but its been several months and they are still much better than before....
    Xbeaus likes this.
  9. Dec 9, 2016 at 7:50 AM
    STEVEO13016
    STEVEO13016 Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    I have had this same issue! replaced my drive side 4 times... finally bought a 30 dollars one off of ROCKAUTO, greased up all the moving parts and BAM, works like a charm. :bananadance:
  10. Dec 9, 2016 at 10:25 AM
    99blacktacoma
    99blacktacoma Well-Known Member
    2017 Grey Tacoma LB Sport 4x4
    Rookie
  11. Dec 9, 2016 at 3:41 PM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    I will be swapping out my chrome OEM ones soon and posting in the FS section
    DustStorm4x4[QUOTED] likes this.
  12. Dec 9, 2016 at 3:47 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    None of mine are broken
    All 4 oem and good
    But at times it seems a little sticky
    Any solution?
    mechanicjon likes this.
  13. Dec 9, 2016 at 4:17 PM
    bry838
    oregon
    What i mentioned in post #8 has really helped mine as far as lubing them up. Just make sure you hit em with many different angles if ya go that route so you can be sure to hit the pertinent linkage. Also try and use an aerosol that foams up a bit when used.(the liquid wrench brand penetrating oil i used foams up well and really aids in the oil to leach onto everything in there)That is if you dont remove the handles to do it. When you lift the handles you will notice some spots under there that you can get the lil applicator straw slipped into thats on your chosen aresol lube.
    PROseur[QUOTED] likes this.
  14. Dec 9, 2016 at 8:13 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    LUBE LUBE LUBE LUBE! youll probably want to use a graphite spray too.
    PROseur likes this.
  15. Dec 9, 2016 at 8:14 PM
    PROseur
    Pussy
    Where
    Where
    Where
  16. Dec 9, 2016 at 8:51 PM
    CodeSeven
    Serge.
    Coachella Valley
    mainly the latch and lock mechanism. but anywhere where there is metal to metal surface contact. hinges, slides, etc. metal to plastic usually isn't an issue unless the plastic is melted to the metal. youll want to use at last a white lithium grease. sil glyde is probably the best product to use all around.
    PROseur likes this.
  17. Dec 9, 2016 at 8:53 PM
    CodeSeven
    Serge.
    Coachella Valley
    you can also use sil-glyde on the backing plate of brake pads to help prevent noise and on caliper guide pins. you know the gas cover lock and latch? lube that up too!
    PROseur likes this.
  18. Dec 9, 2016 at 8:54 PM
    PROseur
    Pussy
    There is no lock on my gas cover or door
  19. Dec 9, 2016 at 10:06 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Yep common with el cheapos. Same issue here. Replaced mine a few times. My driver side is gettin ready to go. I can feel it. Ha. But I just can't being myself to pay that much for an oem. Ugh. Even lubed it all.
    PROseur likes this.
  20. Dec 10, 2016 at 12:12 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    ...am I the only one who's never broken a door handle? My taco is going on almost 20 years now and the handles have never given me any problems.
    06Tacooo, ireymon and 99SuperTaco4x4 like this.
