Door hinge sensor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zoo truck, Apr 28, 2020.
  1. Apr 28, 2020 at 1:30 PM
    zoo truck
    zoo truck [OP] Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I have the master warning indicator light, and beeper periodically going off when i hit a good bump, or pothole in the road. Display shows its the passenger door not fully latched, but it is. Only way to correct this is stop the truck get out and slam the door a couple times then its good for a week or two. Anyone know if its an easy adjustment, or does it need to return to the dealer?
  2. Apr 28, 2020 at 2:01 PM
    pochoboy
    pochoboy Well-Known Member
    idk but...
    is the door open/close sensor near the door hinge or of where I think the switch is located on the door pillar strike? Does your interior lights come on when it does it?
  3. Apr 28, 2020 at 3:53 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It's brand new, let tge dealer not only fix it, but document it, should it need more work or you have related issues down the road.
  4. Apr 28, 2020 at 4:59 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Yah man.... slamming the door repeatedly is definitely the best way to fix it.
    Chew, zoo truck[OP] and SR-71A like this.
  5. Apr 28, 2020 at 5:37 PM
    zoo truck
    None
    I think i figured it out after examining how this system works. There's a switch i believe that sits under a rubber boot on the pillar. I'll spray some de-oxcide contact cleaner in there. Its a professional electronic contact cleaner thats not harmful to anything plastic to see if it helps. Gotta believe that switch is erratic.
  6. Apr 28, 2020 at 5:43 PM
    pochoboy
    doesn't look to bad to remove and replace either:)
