Door Latch Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kahanabob, May 31, 2014.
  1. May 31, 2014 at 12:14 PM
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    2008 4dr pre-runner......Can't open passenger side rear door from the inside.
    comparing, the drivers side the latch has more resistance when i open it, the passenger side less resistance and does not work. opens fine from the outside. i hear sliding motion sound when i put my ear by the door latch on the edge of the door. tells me the issue is at the latch. thought i would check the forum before i open it up and go poking around in there.
    anyone ever had this issue?
  2. May 31, 2014 at 12:28 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    OK i found it, a little slide lever on the edge of the door below the locking mechanism, never knew it was there..............Duh!!!
