Door Lights not Functioning?
Discussion in '4th Gen. Tacomas (2024+)' started by GamerGuy, Apr 2, 2025.
  1. Apr 2, 2025 at 4:01 AM
    GamerGuy
    GamerGuy [OP] Well-Known Member
    Casey
    Alabama
    2025 4WD TRD Sport - Terra
    Does anyone have any experience on these door lights under the door not turning on? Mine have never turned on sincd i bought the truck. Never realized they were there until i saw an option for some OEM replacements that show TRD illuminated on the ground.
  2. Apr 2, 2025 at 4:04 AM
    GamerGuy
    Casey
    Alabama
    Examples of replacements i was referring to.
    Kolter45 likes this.
  3. Apr 2, 2025 at 4:13 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    My door courtesy lights have a white lens cover. Yours may not be equipped and maybe reflectors? Wild ass guess. They should come on with the other interior personal lights and are controlled via switch on the overheat control panel. Can you pop the lens cover off with a trim tool?
    t0p_d0g and batacoma like this.
  4. Apr 2, 2025 at 4:15 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I have never seen a vehicle where that red lens illuminates. Doubting if any Tacoma has wiring running to that spot on the door.
  5. Apr 2, 2025 at 4:19 AM
    snickers
    Kolter45 and ace_10 like this.
  6. Apr 2, 2025 at 4:45 AM
    GamerGuy
    Casey
    Alabama
    "If Equipped"
    Wonder what models have it and how its wired up. I'm guessing my sport doesn't have it then. I would like to get ahold of a wiring diagram and wire it up.
    Thanks!
  7. Apr 2, 2025 at 8:28 AM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    Only the premium option pack has the lights on the TRD OR / Sport models.
    Standard on Pro and TH.
  8. Apr 2, 2025 at 11:24 PM
    caribe makaira
    Caribbean, Puerto Rico
    The connector and wires might be taped to door harness.
  9. Apr 3, 2025 at 3:45 AM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    Can you send me the link to get this light insert? My trd or premium has the door courtesy lights.
    EDIT: Nevermind I found some on Etsy.
  10. Apr 3, 2025 at 8:04 AM
    GamerGuy
    Casey
    Alabama
    Thanks so much.
    I am going to investigate.
  11. Apr 11, 2025 at 1:05 PM
    GamerGuy
    Casey
    Alabama
    2025 trd sport with no door lights
    Door taken apart
  12. Apr 11, 2025 at 1:17 PM
    GamerGuy
    Casey
    Alabama
    Main trunk
  13. Apr 11, 2025 at 1:49 PM
    GamerGuy
    Casey
    Alabama
    Door handle wiring harness
  14. Apr 11, 2025 at 1:51 PM
    GamerGuy
    Casey
    Alabama
    New door projector & plug.
    I need some plug ends now... anyone have any suggestions?
  15. Apr 11, 2025 at 1:59 PM
    GamerGuy
    Casey
    Alabama
    12v measuring from largest red whire to largest green wire across these two different plugs when door is open and when door is closed. Seems that this is where i tap for continuous power.
    @caribe makara there Appears to be 2 plugs needed not just the M10 plug. Can you confirm? Or can anyone who has working lights just pop theirs out and take some readings for me with door open vs closed?
  16. Apr 11, 2025 at 2:16 PM
    GamerGuy
    Casey
    Alabama
    Can you pop yours off and send me some pics of the connectors as well as possible some voltage readings with door open & closed indications
  17. Apr 11, 2025 at 4:27 PM
    caribe makaira
    Maybe...
  18. Apr 11, 2025 at 4:40 PM
    caribe makaira
    red n black are the unlock/lock signal to solenoid. Leave it alone.
  19. Apr 11, 2025 at 4:55 PM
    caribe makaira
    Notice that a dedicated fused positive source is provided by Dome Cut Relay.
    The negative is done at the Main Body ECU.
  20. Apr 11, 2025 at 4:57 PM
    caribe makaira
    You could tap into fused battery source elsewhere, then use door close switch as ground. Which happens when door is opened.
