Door lock actuator 2020 taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mcymanny, Aug 19, 2024.
  1. Aug 19, 2024 at 8:22 PM
    Mcymanny
    Mcymanny [OP] Member
    Emmanuel
    Hiya guys, trying to run diagnosis on my sick trucko, she’s not locking on any doors or my back tailgate (installed pop-o-lock)
    im figuring it’s the door lock actuator, as I’ve check fuses, but maybe I haven’t checked the right fuses? Any one have any insight on this…
    thinking of buying
    This guy Ackoja from Rockauto to DIY
    https://www.rockauto.com/en/catalog...body+&+lamp+assembly,door+lock+actuator,13257
    Any consult would be great! Thanks fellas!
  2. Aug 19, 2024 at 8:24 PM
    999 Well-Known Member
    Texas
    If it were the actuator only one wouldn’t work.
    With all not unlocking it’s the fuse. The wiring or the switch.
    Chew likes this.
  3. Aug 19, 2024 at 8:31 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If none of the locks are working I highly doubt it's an actuator.
    Have you checked the D/L (20A), ECU-ACC (7.5A), and ECU-IG No 2 (7.5A) Fuses in the interior fuse box and the ECU-B No3 (10A) in the underhood fuse box?
    Chew likes this.
  4. Aug 19, 2024 at 8:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked the 20DL Fuse?
    If it's good, You'll need to do test at the body ECU. As the BECU controls the relays and powers to the door locks.
    How did you wire in the Pop-Lock?
    Mcymanny[OP] and Chew like this.
