Door Lock Actuators Revisited....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ts77ts, Aug 15, 2011.
  1. Aug 15, 2011 at 8:07 AM
    ts77ts
    ts77ts [OP] New Member
    Tommy
    2006 Taco 4 door 4x4. Neither driver side door, driver or rear driver side will lock or unlock with the key fob, switch on the drivers door or the switch from the passenger side. Are the two sides seperated by different relays or fuses? I figure the answer is prob going to be actuators, just looking for some extra advice. Thanks in advacnce...
  2. Aug 15, 2011 at 8:59 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Hard to believe that two actuators would suddenly go bad at same time.
    It looks like a single 20A fuse for all the door locks. Could be something wrong with the body ECU as well. This is the document you need to figure it out: Welcome to the forum. :wave:
  3. Aug 15, 2011 at 10:18 AM
    ts77ts
    Tommy
    Thanks for the reply. I am not sure when thety went out, I purchased the truck last week replacing my 1998 Taco. This has been the only issue that I have found with the truck, not a bad problem, just really annoying.
