Door lock, matching key to ignition
Discussion in '1st Gen. Tacomas (1995-2004)' started by ITSDISP, Jun 18, 2023.
  1. Jun 18, 2023 at 12:22 PM
    ITSDISP
    ITSDISP [OP] Member
    David
    2004 250,000 miles with anti-theft 5-speed
    2004, I need to replace the passenger side door lock. I want it to match the ignition, is this even possible?
  2. Jun 18, 2023 at 2:56 PM
    02hilux
    Planet: EARTH
    Yes but you have to take it to a locksmith that can re-key the cylinder to match.
    ToyoTaco25 likes this.
  3. Jun 18, 2023 at 9:09 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    You can rekey them yourself if you’re patient and have the parts, but a locksmith can do it quick. I removed the cylinders from mine and brought them to the locksmith, made it really easy for him.
  4. Jun 19, 2023 at 3:45 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    My friend can do it so fast not even enough time to catch up on the gossip I meant news
    0xDEADBEEF[QUOTED] likes this.
  5. Jun 19, 2023 at 9:57 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    You know the ignition key switch has a limited lifespan.
    when it goes out...you cant get your key out.....and you got to be able to put the key in to turn that to get that all apart...
    without having to drill it out....
    So moral of the story is correct way would to go buy a new matching pair of door cylinder locks.
    And a new key ignition cylinder.
    And take all that to a locksmith and he'll rekey the ignition cylinder to match the new door locks....
    Its pretty common to see both the ignition switch and the key cylinder needing to be replaced in the 150K to 200K range...
    nothing last forever.....
    If the truck aint that old or doesn't have many miles....then never mind......might want to just do the cheap fix.....
  6. Jun 19, 2023 at 10:03 AM
    Bivouac
    Then you could just take all the lock cylinders and put in new wafers.
    Though I must admit I am spoiled I have no idea what real world prices might be. The Lock Smiths do Lock Work I do Fabrication it works out Going on25 years.
