Door lock screeching sound Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99TruckCarGal, Sep 12, 2022.
  1. Sep 12, 2022 at 9:20 PM
    99TruckCarGal
    99TruckCarGal [OP] New Member
    1999 Toyota Tacoma
    Wht 4wd,6cyl.
    I'm new, hate going to mechanic shop, not knowing what's up. What part should I buy on line? and where should I buy on line?
  2. Sep 12, 2022 at 9:39 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Whats screeching?did you lube anything?
  3. Sep 12, 2022 at 9:43 PM
    99TruckCarGal
    1999 Toyota Tacoma
    Wht 4wd,6cyl.
    The door locks, when I push button, reacts very fast, so something is going out soon.
  4. Sep 12, 2022 at 9:44 PM
    99TruckCarGal
    1999 Toyota Tacoma
    Wht 4wd,6cyl.
    No lube, just contact spray on switches.
  5. Sep 13, 2022 at 2:21 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    We can help you more if you articulate well. I still have no idea what’s going on.
  6. Sep 14, 2022 at 8:33 AM
    vtroot
    vtroot Mistakes Were Made
    Eric
    Bay Village, OH
    1995 Toyota Tacoma 4x4 2.7 Manual Standard Cab
    Likely the actuator. They use gears and an electric motor. Probably the motor is going bad. Common issue on Mazdas. You could try cleaning up the electrical connections to see if it helps, but since this isn't a common problem, my guess is replacement is your best bet.
    You could also ignore it. :D As long as your key still locks/unlocks the door, the only downside of a total failure is inconvenience.
  7. Sep 14, 2022 at 10:26 AM
    andywear
    andywear Active Member
    Tulsa, OK
    '99 TRD manual
    Pull the door apart and take a look.
