Door locks not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patchesj, Feb 21, 2018.
  1. Feb 21, 2018 at 7:42 AM
    patchesj
    patchesj [OP] Well-Known Member
    New to me 2010 Tacoma. Power door locks not working. When I hit the lock/unlock button the passenger rear door lock will attempt to unlock but that is the only thing that makes any noise or movement. I've replaced the driver side junction block/body ECU. No change. Checked all of the fuses/voltages, all clear. I'm getting ready to tear the doors apart to get to the actuators... Anyone else run into this? Is it possible that all 4 of the actuators are gummed up or crapped out?
  2. Feb 21, 2018 at 7:54 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I had the same issue with the rear passenger side door in my 2013 DCSB. I replaced the actuator lock motor with a replacement off ebay (got a 2 pack for like 8 bucks). Pretty easy job just make sure to take things slow.
  3. Feb 21, 2018 at 8:03 AM
    patchesj
    Awesome. It looks like full lock assemblies are like $50-$80 for every other vehicle out there but Tacomas... $275. nice. Looks like I'm tearing my doors apart and replacing some motors. ;)
  4. Feb 21, 2018 at 8:22 AM
    Pigpen
    Dan
    Northwest Montana
    Any chance the fob is the problem :notsure:
  5. Feb 21, 2018 at 8:24 AM
    patchesj
    Fob works, well at least the lights flash and I get a beep when locking... Just the doors don't lock or unlock. It's definitely the door locks. I actually disconnected the wiring connectors and sent 12v direct to the motors, no movement.. So it looks like my issue is fried actuator motors.
