Door panel armrest repair
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NelsonTacoma, May 25, 2010.
  1. May 25, 2010 at 5:46 PM
    NelsonTacoma
    NelsonTacoma [OP] This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Don't know if anyone has done this before but my door panel armrest was broken from the day I bought my truck (used). I know most people won't be able to do this repair, but thought you all might like to see how it can be done. It's called plastic welding. I have a kit at work (I work at a car dealership) with different plastic rods and stuff. The armrest is solid and strong now I can't believe I waited 2 months to fix this. Here's my before and after pictures.
    Before. You can see the + shaped crack going from each side and top to bottom.
    After. I ran a bead of plastic weld all the way across past the cracks and then covered the welds with hot glue for added strength.
    desertrunner24 likes this.
  2. May 25, 2010 at 5:48 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Dude that is pretty sweet. nice job
  3. May 25, 2010 at 5:48 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    great write up!! this will definitely help a lot of people!!
  4. May 25, 2010 at 5:51 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  5. May 25, 2010 at 5:59 PM
    NelsonTacoma
    Tucson, AZ
    Nice work! Your's looks way better than mine did. But you were able to access both sides of the crack and I couldn't. I like the leather too. At least now people on TW will be able to find it easily too.:D
  6. May 25, 2010 at 6:04 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    nice! i need to do this as well, can you recommend a kit and/or filler material that would be good to use on this?
    i hate to say it, but its almost like they designed it to crack..i mean, whats the point of that thin groove in there?!
  7. May 25, 2010 at 6:07 PM
    Asgard
    I didn't do it myself, I actually carried it to a bumper repair shop that specializes in plastic welding. They recommended that I weld both sides which was no problem since I was doing my leather install. Mine is still holding up strong. The only regret I have is not welding the whole length of the arm rest seam but from what I remember the crack always seems to start where the seams intersect so I should be ok.
  8. May 25, 2010 at 6:08 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    2016 SR5
    Mine cracked while still under warranty. Dealership hung an entire new door panel to fix a 2 inch crack. Mmmm okay.
  9. May 25, 2010 at 6:09 PM
    NelsonTacoma
    Tucson, AZ
    The kit I used I got from Snap-On, I don't remember how much I paid, I know it was at least $150. Here's a link to a cheap one from harbor frieght. It's $40 and the welding rods are $6.
  10. May 25, 2010 at 6:15 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    that looks like a nice weld...:D good job on the repairs...let us know how it holds up...
  11. Jun 13, 2010 at 2:40 PM
    NelsonTacoma
    Tucson, AZ
    Update for everyone. The armrest is holding up VERY well. I hadn't really noticed the repair until the other day I was talking on my phone (yeah I know I should talk on the phone and drive:eek:) and I was leaning on the armrest and holding the phone to my ear and realized, holy crap, I didn't sink into the door panel!! Yay. The repair turned out so good, I took of the passenger side one and did it too, wasn't as bad as the drivers side, but now it won't get there.
  12. Sep 5, 2011 at 10:48 AM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    how easy is it to take the armrest apart to do this fix?
  13. Sep 5, 2011 at 3:58 PM
    NelsonTacoma
    Tucson, AZ
    It just requires removing the entire door panel. Which is basically held on by some clips and screws. It only takes about 5-10mins to remove the panel.
    Also just to keep the thread updated the armrest is still holding up strong, no issues what so ever.
  14. Aug 15, 2013 at 4:51 AM
    stevensc
    stevensc Member
    South Louisiana
    Tacoma, 2WD
    My 2011 cracked about a month ago, out of warranty I guess. Is it possible to just replace the armrest section with a new one? I haven't removed the door panel yet but loking at the pic in Toll's reply, #10, it looks like the armrest part may be glued in? All those grooves molded into the bottom of the piece look like a natural place to break, a pretty sorry design!
  15. Aug 15, 2013 at 6:11 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    when you say its broken, is it like right in the center of that vinyl (or sometimes leather when replaced) piece thats basically where your elbow lands on the door panel? like right at the point of your elbow you can feel it sinking in? If so my 2012 has been like this for a while now and I just haven't taken it apart to figure it out yet.
    Hopefully this is the issue and its a quick plastic weld fix
  16. Aug 15, 2013 at 9:21 AM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    For people that don't have a plastic welder, or just can't use one, you can do this exact repair using a hot glue gun from a craft store. I don't have any pictures but I used hot glue and a piece of plastic to reinforce it. The plastic i used was from a washer fluid jug, but you could use anything that was thin enough to bend easily. Essentially it was like applying a large patch to the backside of the armrest. Mine has been solid for over a year now, and i highly doubt i could break it if i tried.
    highriserkaiser likes this.
  17. Aug 15, 2013 at 9:38 AM
    Partzguy
    Partzguy Well-Known Member
    Don
    North Texas
    2015 DCSB TRD Sport 4x4
    I just repaired mine last weekend. Even though I've never worked with fiberglass before, I thought I'd give it a try. I bought a $18 Bondo brand fiberglass repair kit from the local hardware store. I started by roughing up the panel surface with sandpaper, then wiped it down with acetone. Then cut the fiberglass matting into 1 1/2" wide strips about 3" long, and laid them in a criss-cross pattern 4 layers deep across the cracked area. It worked perfectly, and now that area of the panel is much stronger than before!
    TRDSport10 likes this.
  18. Aug 15, 2013 at 9:47 AM
    chetweewax
    chetweewax Well-Known Member
    NJ
    15 TRD Sport
    Homelink mirror (Adding soon) Came with truck: FUEL Rims, Mickey Thompsons, Vinyl Tonneau Cover, Remote Start, 20% front window tint
    I did the same exact thing but i went a little crazy with the fiberglass, strong as hell now though
    TRDSport10, desertrunner24 and sawx75 like this.
  19. Oct 12, 2013 at 10:18 AM
    stevensc
    stevensc Member
    South Louisiana
    Tacoma, 2WD
    Thanks for the replies folks!
    I have done fiberglass work on boats so I guess I'll be trying it out on the Tacoma
  20. Aug 27, 2017 at 3:22 PM
    highriserkaiser
    highriserkaiser Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
    4 years since you posted that - how did it hold up?
