Door panel moves w window, video
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hinmo24t, Jul 10, 2025 at 2:29 PM.
  1. Jul 10, 2025 at 2:29 PM
    hinmo24t
    hinmo24t [OP] MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    Anyone ever see this? Window panel moves a bit when opening amd closing
    Thanks
    Damn, file won't upload
  2. Jul 10, 2025 at 2:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have to use a 3rd party host, such as YouTube.
    Tacomaworld doesn't currently support audio or video files.
    If I were to guess, the lift arm or something is out of alignment, which in turn is rubbing the door panel.
    hinmo24t[QUOTED][OP] and Jimmyh like this.
  3. Jul 10, 2025 at 2:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Either that or the door panel is missing some of the clips that fasten it to the door
  4. Jul 10, 2025 at 2:51 PM
    hinmo24t
    tom
    dartmouth, ma
    Thank you, I'll check it out
  5. Jul 10, 2025 at 2:51 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Or the window is off the track or something came apart and is getting pushed into the panel or ...
    Just pull off the panel and look behind and put the window up and down to inspect.
    hinmo24t[OP] likes this.
  6. Jul 10, 2025 at 2:51 PM
    hinmo24t
    tom
    dartmouth, ma
    Thank you
    TnShooter[QUOTED] likes this.
  7. Jul 10, 2025 at 4:02 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    The door panels are surprisingly easy to remove. Watch a couple of YT videos. You'll figure it out.
  8. Jul 10, 2025 at 4:59 PM
    hinmo24t
    tom
    dartmouth, ma
    Update. I got the panel off and didn't see anything wrong while moving glass up amd down. So then put it back together and still did it but I noticed some gasket friction so decided to use aerospace 303 trim cleaner On the glass, inside along bottom edge and essentially lubricated the gasket when rolling down, and she works perfect now. I think dry gasket or sticky glass was friction enough to push outwards a bit on panel
    In case anyone ever needs a reference
    Appreciate the input too
  9. Jul 10, 2025 at 5:07 PM
    hinmo24t
    tom
    dartmouth, ma
    For sure, easy enough where I might remove them again sometime and grease or lube some moving parts. Didn't look terrible in there. No signs of water entry
    I fixed it by just cleaning or lubing the glass, I think it was dry inner gasket or something along bottom of window. Was moving about .25" when going up or down
