Door panel rattle with window down!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pyetime, Aug 1, 2010.
  1. Aug 1, 2010 at 8:56 PM
    Pyetime
    Pyetime [OP] Active Member
    Colorado
    06 Tacoma 4dr TRD Sport
    Anyone exerience a rattle inside the door panel with the window down and you close the door? Sounds really bad like something has broke or like the window is going to fall out of the track. Any advice, anyone ever take the door panel off?:confused:
  2. Aug 1, 2010 at 9:03 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    on the pre-05s theres a small bolt on the side of the door that you can tighten and itll fix it...may be the same here
  3. Aug 1, 2010 at 9:07 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    heres the location on the 1st gens of the bolt...
    it holds the track secure (and apparently they come loose pretty easy)
  4. Aug 1, 2010 at 9:10 PM
    DarrellH3
    DarrellH3 Active Member
    Darrell
    Huntsville, Alabama
    09 PreRunner TRD Sport LB
    I had an '07, it rattled pretty bad when you shut the door, window down or not. I how have an '09. It doesn't clank/rattle when the window is up all the way but it does when the window is down.
  5. Aug 1, 2010 at 9:20 PM
    Pyetime
    Colorado
    Man that would be too easy!!! LOL I just went and checked, no such bolt on an '06.
  6. Aug 1, 2010 at 9:21 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Same here but my warranty company doesn't cover shit out of 50k because it's normal wear and tear. Why sell me a 72k warranty then? I'm a sucker :rant:
  7. Aug 1, 2010 at 9:38 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    thats what im thinking...there should be a bolt SOMEWHERE that holds the window track...it sounds like the same issue at face value
    mine did the same thing and i tightened down my bolt (because i have a first gen) and it fixed the issue)
  8. Aug 1, 2010 at 9:46 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    On my '91 that bolt came out. I had to fix my window track and window. Oh well. It was an easy fix.
  9. Aug 2, 2010 at 3:44 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
