Door panel rattling from speaker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Outlaw, Oct 1, 2009.
  1. Oct 1, 2009 at 7:59 AM
    Outlaw
    Outlaw [OP] Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    My driver side door started rattling when the stereo is on. Its the little panel that holds the window switches and door lock button. I have never replaced speakers or anything. Still shitty stock system, and it rattles even at low volume. Anyone else have this problem or have a fix for this?
    thanks in advance for your help!
  2. Oct 1, 2009 at 8:47 AM
    BSP4x4
    BSP4x4 Guest
    Take the door pannel off, and see if any of the wiring is causing is (maybe tape it down)...also do a search on this forum for Ramaat or dynamatt. I'm thinking about doing this to my doors.
    hope that helps!
  3. Oct 1, 2009 at 8:55 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    thanks for a response...its definatley not loose wiring thats causing the rattle, but the panel itself it rattling.
    is there a way to tighten it?
  4. Oct 1, 2009 at 9:15 AM
    BSP4x4
    BSP4x4 Guest
    I'm not sure? It's funny though, my driver side access door (near the top) makes a rattle when i go over bumps.....haven't pulled the door pannel off yet to investigate...
  5. Oct 1, 2009 at 9:31 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    Its always something isn't it! and will drive you crazy if you let it.
    Somethings i just have to let go...
    I havent experienced the acc door rattle...yet.
  6. Oct 1, 2009 at 9:43 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    you could use some of that anti rattle tape, and put it on the clips that hold the door.
  7. Oct 1, 2009 at 9:44 AM
    BSP4x4
    BSP4x4 Guest
    Could you please xplain?
  8. Oct 1, 2009 at 9:56 AM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    at auto parts stores there is 'anti rattle" tape, it's like cloth. used for dashes, doors, etc...
    take your panel off
    take a piece and wrap it on the clips that snap into the door skin... done.
    (it makes a tighter fit)
    but, you can also check into dynamat or that raamat stuff. I did my doors and rear cab wall and it quiets the road noise down, also any rattles you may find along the way.
    then again, your speaker may just be blown out, the stock ones are cheap.
  9. Oct 1, 2009 at 11:10 AM
    silver6
    silver6 Member
    Frankfort, Ky
    Tacoma Double Cab 4x4 Sport
    Brand new
    My passenger door speaker or aroung that area rattles. Getting on my nerves. Just haven't had the time to get in there and fix it yet. Would it be worth taking to the stealership because it's under warranty?
  10. Oct 1, 2009 at 11:19 AM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    Just pull the door panel off and see?
    Pull the black sail off, take out the white clips and put them back in the sail.
    Then the door panel has two screws, one behind the handle and one behind the door handle. then you push in the black snapper thats holding the plastic at the front of the door and pull the panel right off. Takes about 20 seconds.
  11. Oct 1, 2009 at 4:45 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I tried to stick a cross over in the door panel a while back and broke the rear clip on the window panel, I have two 40w MB components in the front and the panel didn't rattle. If I remember correctly the window control unit is screwed on to the panel, maybe your screws are loose. There is also a yellow clip on the front of the panel, check if you have yours. Also you can unplug and take out the control unit w/ the panel and turn on your stereo, just to make sure it is the panel that is rattling.
  12. Oct 1, 2009 at 4:55 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Mine does too, I just lean my left leg against it and it goes away. I will probaly try the tape fix .
  13. Oct 1, 2009 at 6:54 PM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    I have the same issue bro. I can actually see where the vibration noise is coming from. It's right where the window/door switches connect to the door. Here is my feeble attempt to point it out:
    Like senior taco said, if you rest your leg against it it'll stop the noise. It gets annoying after a while though.
  14. Oct 1, 2009 at 7:10 PM
    SantaCruz'n
    SantaCruz'n Well-Known Member
    Logan
    Temecula
    Saving for the 2013
    All you need to do is take out the two mounting bolts and pull off the panel. There are 10 mm bolts that vibrate loose. Just tighten them up and you will be good to go!! You will find the culprit as soon as you take the panel off, just double check them all. I just did this to my 05 Tacoma yesterday.
    Logan
  15. Oct 2, 2009 at 1:21 PM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    yep thats it! there arent any screws holding this panel on, is there?
    Do I just pry it up, and look for the screws inside?
  16. Jan 25, 2016 at 9:24 AM
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    No one ever replied to this. Did you ever get the rattling noise to go away?
  17. Jan 25, 2016 at 9:26 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Holy thread revival.
  18. Jan 25, 2016 at 9:28 AM
    yazmatic
    Paul
    2012 DCSB TRD SPORT
    Haha Im having the rattle problem and this was the most informative thread
  19. Jan 25, 2016 at 9:42 AM
    Toy1985gc
    Toy1985gc Well-Known Member
    G
    2020 TRD Sport 4WD DCLB Tech Pckg Cement
    3 & 1 leveling kit 32 BFG KO's x17 Method Roost wheels/ TRD Skid
    Thanks for tip man! I have same issue and have complained to dealer . When I first bought my truck in 2013 I took back like 6 months and they removed driver door panel and claim to add insulation- noiese went away for a day and have been getting worse. Added my leveling kit back in Nov of 2015, brought up when I had service done last month. They gave me BS answer that is related to my leveling kit installed! I had the service guy look up all my history- and noticed I brought this up way before I even added leveling kit! and yes- stk speaker suck- they replaced mine under warranty and thats when all the rattle started. Now my right side door does same think when i go over bumps. Gonna get some rattle tape today!
  20. Jan 25, 2016 at 9:44 AM
    TacomaMike37
    13' DCLB MGM
    Are you sure its not the window/door lock black trim piece? I had the same issue with my 13. I pulled up the trim piece put some tape around it and the rattle disappeared.
