Door Panel
Discussion in '1st Gen. Tacomas (1995-2004)' started by Albinator, Jul 9, 2015.
  1. Jul 9, 2015 at 2:07 PM
    Albinator
    Albinator [OP] Well-Known Member
    Utah
    2000 Tacoma 2.7 Manual SR5 4x4; Manual Hub
    How in the world do you get the door panel off!?!? Nor Autzone, Oreily's or Pep Boys and the tool to do it.
    My passenger speaker isn't working so I wanted to take the panel off to test the connections. I have all the screws out. The only thing I can't get off is the handle that rolls the window up and down.
  2. Jul 9, 2015 at 2:16 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    There is a springy u-clip (more mushroom shaped actually) that holds it on. Kinda tricky to get it off. I've been able to get it off sliding a with a piece of thin rag between the handle flange and panel. Sometimes I push it out with a regular screwdriver, or pull it out with short piece of coat-hangar wire with a little 'hook' on the end.
  3. Jul 9, 2015 at 4:04 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yep just slide a rag between the crank handle and the plastic washer and then make a sawing motion with it and it comes right off, just be carefull not to loose it.
    after its off, snap the clip back on the handle, its a snap on fit when you put it together.
    if you do loose it they have em in the "help" section at auto stores
  4. Jul 9, 2015 at 4:17 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    As well as the proper tool.
  5. Jul 9, 2015 at 4:42 PM
    keakar
    karl
    louisiana
    that tool isn't worth crap, I can give you a dozen of them.
    only by blind luck does that thing work well, most times I just use it to give me room to get a screwdriver in to pop the clip.
    the best tool in the world is a shop rag and it wont scratch or damage the door panel unlike that tool
  6. Jul 9, 2015 at 5:05 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    ^^^ can never get that tool to work. rag trick works great.
  7. Jul 9, 2015 at 10:18 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Its very easy, i did both today. You need a wedge tool and a philips screwdriver.
    The latch handle pushes forward. The switches cover pops up and forward.
    There are two screws in armrest and a press in river near the mirror.
    Start at the lock edge with a wedge, feel for the rivet, pop it out. Lift the panel up.
  8. Jul 10, 2015 at 10:15 AM
    Albinator
    Utah
    Sweet guys, thanks for all the help!
    Found the tool at Oreily's and I was not going to spend 8 bucks to remove an omega ring. With another set of hands and a flat head we popped it right out. The reason for me doing this was finding out my passenger speaker wasn't working. Found out that when the door was replaced they didn't connect the wires...good as new now! Found out that when putting the door back together that I forgot to put one of the white clips back onto the door panel when popping it in...oh well, it's on there good.
  9. Jul 10, 2015 at 2:16 PM
    Caligula
    Los Angeles, CA
  10. Jul 10, 2015 at 4:33 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I need to remove my door panel too. Where can I buy some goop to reseal it to the door frame?
  11. Jul 10, 2015 at 5:06 PM
    Caligula
    Los Angeles, CA
    Search for "3M strip caulk" on Amazon. It comes in a box of 12“ strips. This is what they use at the factory.
  12. Jul 10, 2015 at 5:21 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    It should reseal fine just push the weather shield back into what's already there
