Door Rattles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, Aug 6, 2009.
  1. Aug 6, 2009 at 5:34 PM
    kbp68
    kbp68 [OP] hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    I like to drive with my windows open and only use the A/C when it's really hot but I have noticed that all the doors rattle with the power windows down. Closing them stops the rattle. Anyone else have this issue? Has anyone had the door panels off to tighten things up?
  2. Aug 6, 2009 at 5:39 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Do you have power windows or manual roll up?
  3. Aug 6, 2009 at 5:48 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    If you are talking about the windows rattleing when they are say 1/4 -little more than 1/2 way down the window rattles. Have it on my '09. The drivers side does seem to make more noise though. Perhaps due to me being on that side. My ear that is.
  4. Aug 6, 2009 at 5:48 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    A 2006 TRD DC obviously has power windows :p
    I wouldn't imagine it would be too hard to fix, it's easy as pie to take off the door panels.
  5. Aug 6, 2009 at 6:00 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I know it obviously does, it was a quick reply without looking and I thought he could have an older base model.
  6. Aug 6, 2009 at 6:36 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
    Thanks for the quick replies guys. Do the door panels just pop straight out or do they require one of those door panel pry tools? (I always managed to bust most of these off in my Fords & GMs)
  7. Aug 6, 2009 at 6:40 PM
    alextdunn
    alextdunn Active Member
    alex
    san Diego
    05, 4cly, base, Xtra cab, 5 lug lift
    ready lift 5 Lug lift, bed lights, 400 watt inverter, scan gauge II, AFE pro Dry s, second air filter removed
    I have manual windows on my 05 and i notice it a lot i try not to close the door with the window partially down. since it rattles even more but mine is only bad when it is all the way down
  8. Aug 6, 2009 at 6:46 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    There is a loose 10 mm bolt or nut under the door panel.
    The door panel just pops off once you remove a few screws. I think there is one behind the inner door handle, and a plastic plug towards the front of the door that one just push the center of it inwards about 1/4" and pull it out of the panel.
  9. Aug 30, 2009 at 12:02 PM
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    I can agree, Just fixed my rattle tightening one loose and the second nut was completely off. The nuts are for the window track. You might notice while rolling up or down your window. I added a little locktite to the threads before tightening.
    Just a note to be careful pushing the triangular plastic piece that covers the corner of the insde mirror. I pushed hard and one of the the little inserts on the door push thru, so now I need to buy another one so it wont rattle in the future. You will know what I mean when you pull the door panel off.
