Door seal TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tjjmon, Aug 24, 2017.
  1. Jul 24, 2019 at 6:39 AM
    #81
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    It's more of a creaking sound. And yeah, we know what we're hearing.
    Black97v6MT and Plain Jane Taco like this.
  2. Sep 15, 2019 at 4:36 AM
    #82
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It's been several months since I installed the revised seals. Thought I would give a final update.
    The new seals aren't that much quieter than the old ones as far as the squeaking goes. I've gone back to applying Sil-Glyde to them. This product works great. Problem solved...no big deal.
    However, they completely eliminated the cross-wind howl or "kazoo" sound. And the overall wind noise is down as well.
    I spend some time every day on the highway. So solving the howl was important.
    Black97v6MT and zippsub9 like this.
  3. Oct 8, 2019 at 11:45 AM
    #83
    silvertruck
    silvertruck New Member
    2015 SR5
    I just installed the new door seals and that part was easy. Reinstalling the 10mm bolt on the passenger side for door-checker to the A-pillar went in ok. Problem is on the driver side I snapped the bolt like a dumb ass. Anyone know the part number for the bolt? You will notice the doors are a little harder to close but so far no kazoo noise on the highway and it sounds quieter.
    part numbers I used which I believe are from the latest edition of the TSB:
    67861-04062
    67862-04062
  4. Oct 8, 2019 at 5:07 PM
    #84
    Plain Jane Taco
    USA
    I have no idea the bolt number. If it were me, I would simply go to Lowe's and pick up a stainless steel bolt and washer and call it a day
  5. Apr 8, 2025 at 8:13 PM
    #85
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    I spent last Friday down at the Larry H Miller Toyota in ABQ after they agreed to do the service at no charge fixing the defective designed seals per the TSB. Once I got there Toyota stated this would be an added $550 to fix the kazoo noise I've lived with since buying the vehicle new. Toyota advocate supported the NON support. Seems that Toyota "Quality" and supporting their customer base is now a thing of the past.
    Black97v6MT likes this.
  6. Apr 8, 2025 at 9:35 PM
    #86
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    You're being dramatic. The fix for this issue is literally some foam caulk backing rod you can buy at Home Depot for under $10. You just stuff it into the seal along the front door slant and noise is gone.
  7. Apr 9, 2025 at 5:16 PM
    #87
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Great pic: Now i understand. Looks like there are a total of four seals along there (maybe 5?) with the addition of the tubing? No wonder the noise stops. I've never heard this noise on my 2014. Dunno if the TSB applies to that year or if it has already been done in the past before I got it, but I'll be doing this mod this weekend unless it's snowing again here. Thanks to all for all the pics.
