Door Seals and Water Crossings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Harvo, Mar 21, 2018.
  1. Mar 21, 2018 at 6:32 PM
    Harvo
    Harvo [OP] Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    How well do the gen3 doors seal out water at the bottom? I'm going on a ride this weekend on a tail that crosses a river dozens of times. This time of year the water is deeper. I've been through in my jeep when water has been above the 35" tires.
    Three is a good chance the water will be at least up above the bottom door sill. Curious if the seal will hold out water long enough to get across the crossings.
    Anyone know?
  2. Mar 21, 2018 at 6:36 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    You done diff breather mod? Also made sure you aren’t a Tcase and Rear differential 3rd Gen leaker?
    doublethebass likes this.
  3. Mar 21, 2018 at 7:03 PM
    Harvo
    Not a leaker and no breather mod. Its got a valve on it. Been in water axle deep a few times with no issues.
  4. Mar 21, 2018 at 7:05 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I can’t say on the door seals, but if water gets to the door handles it will come in through those I know.
  5. Mar 21, 2018 at 7:06 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's not about the door seals. It's about the 12,000 other holes going into the cab.
  6. Mar 21, 2018 at 9:16 PM
    tcjacado
    tcjacado Well-Known Member
    The hole I would be worried about is the main electrical gromet located in the engine bay that lead into the cab to the fuse box. If you have added any accessories (poked extra holes for new wiring), it may be an issue.
  7. Mar 21, 2018 at 9:28 PM
    phsycle
    phsycle Well-Known Member
    CA
    Standing still, that may be an issue. But as long as he fords correctly, it won’t be a problem.
    Although, after water crossings like that, I would personally change out all diff fluids. Breather valves have been known to still suck some water in.
    tcjacado[QUOTED] likes this.
  8. Mar 22, 2018 at 4:00 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    If water is that high I'd be concerned with water in the intake...
  9. Mar 22, 2018 at 5:10 AM
    gator2764
    gator2764 Well-Known Member
    Mid Ga
    2016 TRD DCLB 4X
    I can just see a trip to the dealer for warranty work.
  10. Mar 22, 2018 at 7:01 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    I've been in water up to the sills as well. Just keep moving forward and you should be fine.
