Door seals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jetfixr, Feb 23, 2022.
  1. Mar 25, 2022 at 1:27 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    "RR" is "Rear" in Toyota parts-speak, so yeah, that makes sense.
    For others curious about access cab, here are all the part numbers for these:
    67895-04010 - Right Rear (Access Cab)
    67896-04010 - Left Rear (Access Cab)
    67895-04020 - Right Rear (Double Cab)
    67896-04020 - Left Rear (Double Cab)
    Jeff
  2. Mar 29, 2022 at 6:27 PM
    Hawapino
    Hawapino Well-Known Member
    Ivan
    Denton, Tx
    2015 Super White DCSB TRD OR 6MT
    Just installed mine today. There’s definitely a noticeable difference, especially with my doors being sound deadened.
    wi_taco likes this.
  3. Feb 15, 2023 at 10:13 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Would someone please measure the weatherstripping? Is it 1¼" wide by ¾" thick? I'd rather pay $15 locally than $40... TIA and I appreciate the mod OP!
    Ricardo13x likes this.
  4. Mar 1, 2023 at 6:11 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Do the seals cover the full length of the door open space, @Jetfixr? I picked up a set the other day for my 2015 DC and test fitting them by holding them against the door it looks like they'll end 4-5 inches above the bottom of the door. Did fitting them with the pressure sensitive tape let them cover the entire space from top to bottom?
  5. Mar 2, 2023 at 3:03 PM
    4xdog
    Santa Fe, NM
    I was at the dealer today and had the chance to double check the fit of those seals on a Gen 3. As expected, they match up exactly like on a Gen 2. The seal stops about 2-1/2 inches before the bottom of the two doors on the Gen 3s, too. All good.
  6. Mar 2, 2023 at 3:06 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    seems the access cabs can't have enough door seals. even my 3rd gen has some bad road/wind noise with the updated seals.
  7. Apr 8, 2025 at 3:45 PM
    MACKT28
    MACKT28 Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Did you end up doing the rear door seals by chance?
