Door Sill Protectors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhyNotFab, Feb 5, 2011.
  1. Feb 5, 2011 at 11:29 PM
    WhyNotFab
    WhyNotFab [OP] Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
  2. Feb 5, 2011 at 11:51 PM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    I wish the actual product was pictured to get a better idea of what to expect before ordering lol.. I hate when websites have the "Notes: Picture does not accurately portray actual item."
  3. Feb 6, 2011 at 6:25 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    First, you are asking in the 2nd Gen section if these step guards will fit your 1st Gen tacoma :confused: You'd probably have better luck asking the 1st Gen guys. We don't know the dimension fo your door sills.
    Why don't you look for a product made for your specific application?
    http://ventshadedirect.com/product.php?productid=152830&cat=0&page=1
    The AVS step shield is much better than the Toyota one. Sure they don't say "Tacoma" on them, but they cover so much more of the exposed area.
  4. Feb 6, 2011 at 6:38 AM
    samhain
    samhain Well-Known Member
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    I made my own out of skateboard grip tape. It was cheap and works well.
  5. Feb 6, 2011 at 7:03 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    I've got them and honestly, they're not much more than a really thick sticker. They don't even cover out to where the metal turns down. That's the area that needs protecting the most. They do look good though. It measures 2 3/8" x31 3/8". Also, on 2nd gens, you have to remove existing sill cover. There is a standing seam running the length of the door opening, it has a couple of v's bent into it.___^_______^_____. The door sill protector has corresponding v's cut into it for alignment. I say this so you will know the back edge is not straight, it has v notches cut into it, to be covered by sill cover. Unless you can tuck it under your existing sill cover(IDK about 1st gen), you're going to have to trim it straight. But like I said, it's not much more than a thick sticker. Should be easily trimmed. Hope my ramblings help you.
  6. Feb 6, 2011 at 10:18 AM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    I can measure my own door sills, was just asking if one of you guys could possibly measure yours so I can compare lol. (Thanks 05 TRD Sport, exactly the info I needed) I hadn't found the specific ones when I posted, if the Tacoma ones would fit I wouldn't mind using them, but the AVS should be nice too. Thanks!
  7. Feb 6, 2011 at 10:24 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I have those exact ones, just havn't installed them yet. As mentioned, they seem to be just thick stickers.
    Fronts: 22 1/2" by 2 1/2"
    Rears: 17 3/4" by 2 3/4"
  8. Feb 6, 2011 at 10:28 AM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    The skateboard Grip tape idea sounds good I think i will try that !!
  9. Feb 6, 2011 at 10:30 AM
    225nontypical
    225nontypical ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    i have those and mine are getting destroyed i am going to have to replace them but i will not buy these again. i will buy something different
  10. Feb 6, 2011 at 4:09 PM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    Same here!
  11. May 10, 2011 at 5:34 PM
    Oceanrunner
    Oceanrunner Well-Known Member
    I just bought a set of the Toyota door sill protectors for my new 2011 TRD sport DC.
    Very disappointing... Complete waste of $25.:mad: The online picture is misleading. Wish I knew about the AVS before hand.
  12. May 11, 2011 at 4:36 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    x2
    You can get strips of this kind of stuff at Walmart cheap.
  13. May 11, 2011 at 5:29 AM
    samhain
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    I'll get some pics of mine up tonight.
  14. May 11, 2011 at 5:42 AM
    maestroz2
    maestroz2 Well-Known Member
    Dave
    Erie, PA
    2010 DoubleCab Pyrite Mica TRD Sport SB
    TRD Skid Plate, Toyota Bed Mat, WeatherTech window visors, WeatherTech Floor mats, Access LE Bed Cover, Rocky Mounts Bike mounts, Astrostart 2-way Remote Start, TRD bronze beadlock wheels, Factory roof rack.
    Has anyone tried to get the door sills coated with line-x or any of the other truck bed linings out there?
    I have the oem door sills and they suck, they do not cover the corner which sees the most abuse.
  15. May 11, 2011 at 10:36 AM
    DOT
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    I wonder if the line-X spray can stuff would work ok on this part ?
  16. May 11, 2011 at 10:59 AM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Yes it does! I used Rusto Truck bed coating spray and taped off my area. It has been on there a year and never once has peeled or chipped off.
  17. May 11, 2011 at 11:04 AM
    DOT
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    Sold! Ill have to pick up a can
  18. May 11, 2011 at 11:08 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    My protecters say "Tacoma" on them...came installed on the truck when new. I saw once where a guy cut out the word "Tacoma" to where the trucks paint showed through...looked sharp!
  19. May 12, 2011 at 5:14 AM
    maestroz2
    Dave
    Erie, PA
    any pics of what the spray looks like on?
  20. May 12, 2011 at 9:47 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I made mine too. These are made out of a vinyl grip tape (used in gym shower's). I had these laser cut. It's a little easier on bare feet than skateboard grip tape.
    Climberclimb likes this.
