Door sill wear? What to do about it?
Discussion in 'Detailing' started by Alderleet, Aug 13, 2012.
  1. Aug 13, 2012 at 3:08 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Alright, you can see the wear... Ugly right.
    What can i do about it? Has anyone covered it, or coated it with something to fix it? Anyone rhino-line it or something?
    I'm trying to find something to make that look less hideous when i get in and out of my vehicle.
  2. Aug 13, 2012 at 3:11 PM
    BDJ
    BDJ Well-Known Member
    Brandon
    West Monroe
    2012 TRD OR 4x4 DBL Cab MGM
    You can buy sill protectors that stick on. My truck came with them and obviously from what is happening to yours they are worth it.
  3. Aug 13, 2012 at 3:12 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Why not just replace it with either OEM or diamond plate aftermarket?
  4. Aug 13, 2012 at 3:21 PM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I'm talking about the fucked portion where my paint has magically dissapeared, not the plastic "sill" (its in the same area, so i just ballparked it on what to call it)
  5. Aug 13, 2012 at 7:00 PM
    wolftree
    Rick
    Ohio
    Clean it, sand it, prime it and paint it.
  6. Aug 14, 2012 at 6:25 AM
    BDJ
    Brandon
    West Monroe
  7. Aug 14, 2012 at 7:21 AM
    Madjik_Man
    Colorado Front Range
    Does your door shut properly?
    Seems like you're getting excessive/unnecessary rubbing from the bottom of your door.
  8. Aug 14, 2012 at 9:04 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    stop dragging yer lead foot :p
    muh junk is 12 years old and still looks great
  9. Aug 14, 2012 at 9:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    ^^This, lift your feets :D
  10. Aug 14, 2012 at 1:13 PM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Unfortunately, i didnt cause it. It was prior owner. I've only had the truck for less than a year.
    Still, the question stands, what can i do to cover it and prevent more damage? I'm not good at painting, so that shit is out. (I dont want it to look more like ass)
    2000 Access cab.
  11. Aug 14, 2012 at 2:01 PM
    Pugga
    Massachusetts
    It's down to bare metal, you have to use some sort of paint to cover it regardless of what you do. If you just throw a cap on it, the bare metal will eventually rust underneath it.
  12. Aug 14, 2012 at 2:29 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    rattle can it... it don't have to be perfect if you intend to cover it up
    [​IMG] [​IMG]
  13. Aug 14, 2012 at 6:02 PM
    wolftree
    Rick
    Ohio
    You do not have to be a professional painter to paint that small area. Mask or cover everything but that area. Wash it down, sand it, prime it and spray can paint it Let it dry between coats.
  14. Aug 14, 2012 at 6:31 PM
    Madjik_Man
    I never touched a can of spray paint in my life until this past year when I started to touch up, or black out, parts of my truck.
    The old adage, "if I can do it, any one can" is very much applicable to spray painting.
  15. Aug 19, 2012 at 1:40 PM
    JeanClaude
    JeanClaude Well-Known Member
    East Atlanta
    2009 Tacoma Prerunner
    Clear bra on it would keep it nice.
  16. Aug 19, 2012 at 2:55 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    What these guys said. :thumbsup:
  17. Aug 19, 2012 at 3:21 PM
    SuperWhiteSLT11
    SuperWhiteSLT11 Active Member
    STEVE
    PHILA. PA.
    SLT LONG BED
    SUNTEK WINDOW TINT 15% FRONT & 20% REAR DOORS & SLIDER , EGR WINDOW SHADES ,
    Looks like the bottom of your door is rubbing on the sill and top edge of the rocker panel , if you spot refinish the sill its just going to wear off again , you may have a bad hinge , open the door all the way and try to lift it from the bottom the door should be tight with very little play, if you don't want to spray paint the sill at least , touch it up after you find out what's causing the problem.
    :confused:
