Door tire rating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by greg2513, Dec 2, 2016.
  1. Dec 2, 2016 at 8:15 AM
    greg2513
    greg2513 [OP] New Member
    My new 2017 TRD 4x4 Sport has a tire rating of 29 PSI on both front and rear tires. I know this is very low and was wondering if anyone else's door says 29 PSI on a new sport.
    Wheresmytaco likes this.
  2. Dec 2, 2016 at 8:20 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    "door tires" must be a turd gen thing? My truck doesn't have a tire for the door.
    T6A1C9O, T4RFTMFW and Hank Heel like this.
  3. Dec 2, 2016 at 8:23 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    It's normal. Seems low to you, but that's the balance between MPG and ride comfort that the factory has decided.
    Mine is the TRD OR package with the 16" wheels and door Sticker says 30. I have them filled to 33F/32R. Much stiffer ride and I don't have the factory wheels anymore, just the stock tires and different suspension.
    There's nothing that says you can't adjust your own pressure settings though. Try different settings.
  4. Dec 2, 2016 at 8:27 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I run 29 rear, 30 front on my 2015 DC.
  5. Dec 2, 2016 at 8:31 AM
    UAL777jet
    UAL777jet Well-Known Member
    Bill
    Norwalk, IA
    2019 Tacoma TRD Pro Voodoo Blue
    TRD Performance Air Intake
    Same on my 2016 Sport, dealer always puts them at 32 psi. Switched to TRD pro wheels and tires, same thing 32 psi.
  6. Dec 2, 2016 at 8:33 AM
    greg2513
    Thanks guys. I just had never seen a vehicle with a 29 psi rating.
  7. Dec 2, 2016 at 8:34 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
  8. Dec 2, 2016 at 8:35 AM
    rcw65
    rcw65 Member
    Rick
    SC
    2017 Toyota Tacoma TRD PRO - Super White
    275 x 70 x 16 BFG KO2, removed charcoal filter, K&N filter, LED for; interior lights, bed, back-up and license plate. Pioneer 8200 NEX / car play / Idatalink, Raised Tacoma black letters ( tailgate) Red line Tuning hood quick lift Elite, Factory roof rack.
    You can use a thermo heat gun to test the even heat temperature across the tire road surface patch to determine the correct air pressure for your tires. You will have to bring them up to temperature before taking your readings. It's a bit of trial and error to get it right.
  9. Dec 2, 2016 at 8:38 AM
    gpb
    Atlanta
    Does this produce a functionally different result from doing a chalk test, which is probably a bit easier to do for folks who don't have access to a thermo imager?
  10. Dec 2, 2016 at 9:51 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    PSI, in of itself, tells you nothing of load requirement. Load requirement is whatever load index the tire is at a particular PSI.
    The recommended PSI goes out the window anytime tire load index and/or size changes from stock because load requirement stays the same.
    I highly recommend the Toyo tire link posted earlier.
  11. Dec 2, 2016 at 10:24 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Mine had a supplemental sticker for the BFG AT D load ratings that said 46. 46 was too much and causing more wear in the center. I think 29-30 is fine with the OEM tires. Seemed to be just right on my 2009.
  12. Dec 3, 2016 at 8:41 AM
    vale46
    vale46 Well-Known Member
    FL
    2017 TRD Pro
    I'm still on the stock 30 front and back
    (Door sticker says the same)
  13. Dec 3, 2016 at 9:18 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    I've been experimenting with running helium in my tires....great MPGs :D
  14. Dec 3, 2016 at 9:35 AM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    My '11 TRD OR with 16 inch wheels also states 29. That is just for comfort. I run 34. no undue tire wear. Also, set to 29 triggers the tpms if the temp falls dramatically.
  15. Dec 3, 2016 at 1:04 PM
    rcw65
    rcw65 Member
    Rick
    SC
    At 66 years old, comfort is good.
  16. Dec 3, 2016 at 1:22 PM
    TACO TX
    Kelly
    Denison ,Texas
    I use to run my tires at anywhere from 34 down to 32. When I went down to 30 it was like night and day as far as feeling bumps and imperfections in the road. Took alot of the harshness out of the ride and no noticeable difference in fuel mileage. The chalk test is a great way to find that sweet spot as well.
  17. Feb 8, 2017 at 6:31 PM
    JH Taco
    JH Taco Well-Known Member
    2016 Tacoma TRD Sport - Inferno
    My 2016 TRD Sport calls for 29 pounds (door sticker). At that level it rides smooth on-road, but with a year's ownership now, I run 35 during the Spring and Summer (40 for long highway trips), but lower to 30 for Fall (wet leaves) and Winter (snow). This has worked very well for me here in Columbus, OH, and I have made 2 round trips to Florida as well. I have the stock Toyo Open Country tires.
