Door unlocks after locking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GraphiteComa, Nov 20, 2018.
  1. Nov 20, 2018 at 7:29 PM
    GraphiteComa
    GraphiteComa [OP] Member
    Hello everyone,
    I feel like there would be a simple fix for this so I feel dumb asking. When I try to lock my Tacoma with the fob and the finger sensor on the door handle it locks and beeps once per normal. Then immediately after it unlocks with a single beep. Unlocking normally gives off two beeps. I tried locking from a distance and it still unlocks.
    I look inside and see door ajar on the dash while the driver door is open. Then I close the door and the ajar message goes away. I tried just pushing the sensor in while the door is open and the message goes away so it looks like the sensor is working for the driver door. Only the driver door unlocks. I tried opening and closing all doors and the problem persists. I'm not sure what else to check. Any help would be appreciated.
    2018 TRD Off-road btw.
  2. Nov 20, 2018 at 7:39 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Where's your spare fob?
  3. Nov 20, 2018 at 7:39 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Door ajar should be a long solid beep. Maybe another fob inside vehicle.
    KellyJoe likes this.
  4. Nov 20, 2018 at 7:45 PM
    GraphiteComa
    The spare key is accounted for and not in the vehicle.
    Also usually fob inside the vehicle is also a long solid beep.
  5. Nov 20, 2018 at 7:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Change battery.
  6. Nov 20, 2018 at 7:48 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Did this just start happening and how long have you had the truck?
    Also, have you done any recent mods prior to this issue?
  7. Nov 20, 2018 at 7:51 PM
    GraphiteComa
    Should I change the fob battery? Car battery?
    I have had the truck 6 months and this started today. I have had an amp and speakers installed a couple weeks ago.
  8. Nov 20, 2018 at 8:03 PM
    VegasTool
    VegasTool Well-Known Member
    Las Vegas
    2017 TRD OR
    You do have possession of the 2nd fob right? I mean you sure you don't have somebody fucking with you looking out the window right?
  9. Nov 20, 2018 at 8:05 PM
    GraphiteComa
    The spare key fob is currently back home at my parent's house. I called to confirm to get eyes on it. I will be able to get my own eyes on them tomorrow night.
  10. Nov 20, 2018 at 9:36 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Change fob battery. If that does not work, take back to stereo installer.
    tcjacado likes this.
  11. Nov 20, 2018 at 9:52 PM
    GraphiteComa
    Thanks. I will do that and see what happens.
    hiPSI[QUOTED] likes this.
  12. Nov 21, 2018 at 7:47 AM
    GraphiteComa
    Half update:
    this morning before work the issue is no longer there. Will see if the issue comes back. Will still change battery when I can. I will also edit this post with a very poor video I took last night when I was having the issue.
