Door won't unlock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mariotaco, Sep 27, 2015.
  1. Sep 27, 2015 at 7:40 AM
    Mariotaco
    Mariotaco [OP] Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    Hello, not to long ago the drivers side door stopped opening with the remote. It does open with the key, manually, and also by pushing the unlock button on the arm rest. Does anybody know what may cause the driver door to not unlock only with the remote ?
  2. Sep 27, 2015 at 7:44 AM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    Well since you said it works with the switch, I'd rule out the actuator.
    Do all the doors unlock when pushed twice? Except the drivers door?
  3. Sep 27, 2015 at 7:48 AM
    Mariotaco
    Mario
    El Paso, Texas
    11 SR5 4x4
    Yes the do. I was thinking that something may have gotten stuck but it doesn't make since that it unlocks with the switch
  4. Sep 27, 2015 at 10:17 AM
    Mariotaco
    Mario
    El Paso, Texas
    11 SR5 4x4
    I lied it doesn't even unlock wi the switch but it does lock.
  5. Sep 27, 2015 at 12:26 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Check the battery in your remote
  6. Sep 27, 2015 at 12:36 PM
    mtnceej
    mtnceej Well-Known Member
    Gary
    Crestline, CA
    2015 SW DCSB TRD OR 4X4
    ICON Stage II TC UCAs Demello Bumper TRD Cat Back Exhaust
    From my amateur opinion...If it doesn't unlock with the switch or key fob, I would say actuator or wire to the actuator..if the switch does work but not key fob then possibly just a wire to the actuator coming from the keyless remote brain, not sure if separate from the ecu or not .
    You can always check the power wire with a multimeter to see if it's getting voltage or not when the switch is pressed to isolate it to an actuator issue rather than wire.
    Also work taking a look to see if the actuator came loose from the lock push rod...
    I could be way of base since I've not taken the panel off of a Tacoma door, just throwing some ideas out there.
  7. Sep 27, 2015 at 12:38 PM
    DEMikey
    mikey
    delaware
    2013 red taco
    I'm leading toward the actuator also.
