DoorDing's 2012 Tacoma
Discussion in '2nd Gen. Builds (2005-2015)' started by DoorDing, Sep 9, 2012.
  1. Aug 23, 2013 at 5:28 AM
    #121
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    Thanks for the reply. Looking forward to pics.
  2. Sep 19, 2013 at 9:17 PM
    #122
    bullaculla
    bullaculla IKA fabrications
    Honolulu HI
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings.
    Great wheeling pics. Its not often that I wish I lived in the mainland.
    Waiting on exhaust re-route pics.
  3. Sep 19, 2013 at 9:35 PM
    #123
    DoorDing
    DoorDing [OP] Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    I forgot I'd never posted any trip photos.
    I'm doing an oil change this weekend, so I'll shoot the crossover for you.
  4. Sep 20, 2013 at 3:47 AM
    #124
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Have you installed that suspension yet? :playball:
  5. Sep 20, 2013 at 9:06 AM
    #125
    DoorDing
    Bodie, CA
    yes
    I installed the bump stops and put the bushings in the springs. Oh, and I installed the rest of it back into boxes. Baby steps.
  6. Sep 29, 2013 at 12:45 PM
    #126
    brian121599
    brian121599 New Member
    Brian
    Virginia
    '13 DCLB SR5 4x4
    16x8 Dick Cepek Rims, 265/70 16, Lund Gensis Elite bed cover
    How hard was your Pop n lock install? Did it affect your back up camera at all? ie angle or anything after moving it to the opposite side of the handle? Just got my 2013 DCLB and orded my tonneau. Need a lock for the tailgate now but affraid of installing the powered pop n lock due to the possibility of lock outs. Thanks!
  7. Sep 29, 2013 at 12:52 PM
    #127
    DoorDing
    Bodie, CA
    yes
    Easy. Maybe took 30 minutes, and it didn't significantly affect the camera POV.
    There's a gasket from the OEM handle that has to be transferred to the new part, and I had to stretch it a little to get it to fit. Other than that, it was a simple installation. I don't use the lock often, and I didn't want to mess with the wiring for the powered model.
  8. Sep 29, 2013 at 6:39 PM
    #128
    Biscuits
    Biscuits Slow going & dirt free.
    Rusty Shackleford
    2014 PovertyCharged & 2010 PreRunner
    SWANG AN' BANG
    I've been following your build for awhile now and I'm really liking what I see. Highly jealous of the territory that's immediately available to ride and explore.
    There is +, -, & 0. Your explanation for the + and - is correct insofar as the manufacturing vs OEM tolerances is concerned, but the 0 is a neutral, meaning it's on par with OEM measurements. For example my Dakars had a 0 and a - and I installed them with the neutral on the passenger side. As a result I had ghetto lean until I reversed the leaf packs. Once I did that the lean disappeared.
    Great find.
  9. Sep 29, 2013 at 6:53 PM
    #129
    DoorDing
    Bodie, CA
    yes
    Thanks. I wasn't aware of the O designation. I don't remember seeing that before, and it makes sense. I would've been happier with a O and - , since I don't want quite that much lift.
    The only difference in the VIAIR RV model is it comes with a second air hose and an air chuck to reach an inside dual. I bought it instead of the regular 400P since it was a little cheaper and came with the accessories. The bag was junk, but everything else works well.
    You should check out Bullaculla's truck. Similar suspension (his is installed), and some other very nice additions.
  10. Sep 29, 2013 at 7:00 PM
    #130
    Biscuits
    Rusty Shackleford
    SWANG AN' BANG
    Thanks for added info about the compressor. I followed the link you provided to your thread about it and answered my question. More detailed info is always appreciated though :)
    I'll snap a picture of my Dakars tomorrow; the lean that I had before I swapped the 0 to the drivers side was ridiculous. I'm sitting on Icons on all four corners; should be creating a build thread sometime soon.
    I've actually been following Bullaculla's build thread and have gotten some good ideas (as well as from yours) on what I'd like to add to my truck. This place = #1 capital expenditure. :D
  11. Oct 4, 2013 at 6:27 PM
    #131
    DoorDing
    Bodie, CA
    yes
    Ordered a set of Wet Okole seat covers today as part of the now closed WO Group Buy.
  12. Oct 4, 2013 at 6:41 PM
    #132
    bullaculla
    Honolulu HI
    I love my WO seat covers! What color/options did you go with?
  13. Oct 4, 2013 at 6:59 PM
    #133
    DoorDing
    Bodie, CA
    yes
    Standard Black, with Charcoal #11 center, front & rear. Front seat back pockets, passenger lumbar support. No piping, no applique, no heater, no gun or sunglass pockets, no pet leash.
    WO gave us 20% off, and included a center console cover & seat care kit. $476, delivered.
  14. Oct 11, 2013 at 2:56 PM
    #134
    DoorDing
    Bodie, CA
    yes
    A few things lined up, and I got under the truck this afternoon. I had the re-route done a few months ago.
    The OEM mount was re-used to support the new pipe. There's a dark spot on the skid in front of the crossmember where the OEM pipe rubbed the skid.
    There's about 2" of clearance between the pipe and driveshaft. I've checked to see if the shaft was getting hot (it wasn't). I thought about adding a heat shield just above the exhaust to separate it, but I may not worry about it.
    The stub was plugged and left on in case I wanted to return to the OEM routing. It was also easier to weld that way, and it hasn't caused any problems.
    Usethe2nd and Crom like this.
  15. Oct 11, 2013 at 3:02 PM
    #135
    DoorDing
    Bodie, CA
    yes
    I applied a heavy coat of FF a year ago using an undercoating gun. After 10,000 miles, including a few weeks in Colorado and Utah, this was the worst dust accumulation I could find.
    That's the rear side of the crossmember in front of the rear axle. Any more dust than that has easily washed off. Not that I expect to see much rust on a new vehicle, but other than the exhaust, I found none. Before I re-apply this fall, I'll drop all of the skids, put it on some ramps, and clean it up a little with a brush and Simple Green.
    I also installed the gas tank skid. More here.
  16. Oct 28, 2013 at 11:24 AM
    #136
    TACOlin
    TACOlin Well-Known Member
    Colin
    Marietta, GA
    2010 TRD Off Road 4x4 DC SB
    URD Short Shifter, TRD Shift Knob, Rear Leaf Spring TSB, Flowmaster Super 40 muffler w/ 2.5" pipe and 3" tip, Cobra CB radio, 2' Truck Spec antenna, under hood PA speaker, JVC KW AV71BT Headunit, Anti-theft tailgate protection mod, locking bed storage compartment mod
    First off, sweet build! Fun to look at. Also, can you tell me what you think about your scangauge II? I'm straddling the fence between the scangauge and ultra gauge because I'm not sure I could reap all the benefits of the different functions of the scangauge for what I do. So did you ever look into the ultragauge? I'm interested to hear your opinion, thanks!
  17. Oct 28, 2013 at 11:11 PM
    #137
    DoorDing
    Bodie, CA
    yes
    Thanks.
    I bought the SGII several years ago. It'll do a little bit more than the UG, but the UG is nicer to look at and costs much less. From what I've seen, the only feature of the SGII has that makes much of a difference over the UG is the ability to monitor ATF temperature. If I was buying today, I'd probably get the UG.
  18. Oct 29, 2013 at 6:49 AM
    #138
    TACOlin
    Colin
    Marietta, GA
    Thanks for getting back to me. And yeah I've been doing alot of reading on the two and other than the screen customizability of the SG, the only difference I noticed was the ATF temp. But I have a 6-speed so Im pretty sure I wouldn't be able to use that function so I think I'm gonna go with the UG. Plus the price difference is nice :D Thanks!
  19. Nov 22, 2013 at 7:35 PM
    #139
    bullaculla
    Honolulu HI
    I finally ordered a Viair 400P-RV. Thanks for the suggestion :D
  20. Nov 22, 2013 at 8:00 PM
    #140
    DoorDing
    Bodie, CA
    yes
    Still happy with mine, but I had a problem with it last week. The included air chuck screws onto the stem, and the rubber insert balled up and died. It still worked, but it did leak a little. I've only got 16 or so cycles on the thing, so I'll be talking to VIAIR about it. I'd prefer the clip-on style chuck they used to ship.
    A friend had a good idea - pick up a cheapo HF air accessory kit for a back up. Oh yeah! I know your girl loves to help, but make it very clear that the compressor will get searingly hot everywhere but the black foam handle. I know that, but still caught myself bumping a shiny part and wincing.
