Doors won't unlock when very cold outside except the driver's door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by redrx8, Jan 19, 2019.
  1. Jan 19, 2019 at 5:27 AM
    redrx8
    redrx8 [OP] Well-Known Member
    Hi, the doors on my 2017 tacoma won't unlock when it's very cold outside. The only door that unlocks it the driver's. I try with my fob by double clicking the unlock and nothing happens, even pressing the unlock button on the driver's door won't unlock the doors. I have to start the truck and let it run for a bit, then the doors unlock. It's annoying when I have to go somewhere with my wife and can't unlock the doors until the truck ran for a bit.
    Does anyone else has that problem and what has been done to fix it. Needless to say that as I get to the dealer the problem cannot be duplicated since the truck is warmed up.
  2. Jan 19, 2019 at 5:29 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Guess you will have to leave the truck overnight at the dealership for them to duplicate it.
  3. Jan 19, 2019 at 5:30 AM
    capequahog
    capequahog Well-Known Member
    Cape Cod MA
    17TacomaDblCabTRDSport
    in the dreaded black
    what model Taco ? some you can program so all doors unlock
  4. Jan 19, 2019 at 6:34 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    While true (I used Carista to tweak the little things) the OP's is truck is apparently defective.
    Simple as that.
  5. Jan 19, 2019 at 8:04 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Reach over and open the passenger door for her.
    G.
    02Duck, Hobbs and jmneill like this.
  6. Jan 19, 2019 at 8:08 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    While a nice idea... the solution is to repair the faulty system, not change personal behavior
  7. Jan 19, 2019 at 8:17 AM
    jmneill
    SE
    The OP states he's literally delaying departures while waiting for the truck to warm. Sounds like the temporary but immediate solution would be to lean over and open the door until he can drop the truck off for a couple days..
    02Duck likes this.
  8. Jan 19, 2019 at 8:22 AM
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    You forgot to include obvious in your temporary/immediate solution... in that case I agree :boink:
  9. Jan 19, 2019 at 7:28 PM
    redrx8
    The dealership is 2.5 hour drive from home it's not really convenient to leave overnight but I might have to do it before the warranty is up. I believe I tried to open the back doors manually but could not, since it's going to be -31C tonite and need the truck tomorrow, I'll try to manually open the doors.
  10. Jan 19, 2019 at 7:30 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Check the door strikers and latch mechanisms for grease. Sometimes they will be severely overgreased which makes them sticky in the cold and they won’t function.
  11. Jan 19, 2019 at 7:36 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I worked with a asshole that had a similar problem, but none of his door would open.
    Due to it being minus 2 degrees that night and almost everyone on the third shift crew taking turns pouring water over his car may have had something to do with it.
    mrkabc likes this.
