Doozy4212's Better Truck Drawer Build/Guide.....AGAIN (V3)
Discussion in 'Other Builds' started by upTOPOverland_Drew, Feb 8, 2019.
  1. Feb 10, 2019 at 9:11 PM
    upTOPOverland_Drew
    upTOPOverland_Drew [OP] upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    I came across that build awhile ago! Amazing work, and extremely well built
    Manfred[QUOTED] likes this.
  2. Feb 11, 2019 at 7:24 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    1/4" - 20
    I used six holddowns.
    I also used backing washers under the bed. I slipped the washers on the rivnuts before setting (compressing) them.
    It takes an extra set of hands, but I feel the washers help spread the load on the plastic bed.
  3. Feb 11, 2019 at 7:49 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Makes sense. I think the grip range for the rivnuts I ordered was .165-.265 and the the bed is only 3/16” thick or .1875 so I plan on using a small washer as well.
  4. Feb 11, 2019 at 8:15 AM
    Scott B.
    Scott
    Georgia
    The washers I used were slightly larger in diameter than the top of the rivnut.
    I found them on McMasterCarr.
  5. Feb 13, 2019 at 4:58 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    UPDATE 2/13/19:
    Icon 10 Gallon water tank showed up yesterday. It's exactly what I need with the exception of the fill hole is different then I expected. I was expecting a 1 1/4" threaded insert as opposed to a neck that will accept a hose with a 1 1/4" ID hose. This would not be an issue if 1 1/4" hose was more flexible. I need to make a hard 90* turn in 4.5" for this to work and 1 1/4" fittings are proving difficult to find.
    Regardless, I got my other fittings installed. The two that are joined at the bottom will lead to a filter and then through the pump. The other fitting is for the breather that I will mount on the bed rail to prevent contraction and swelling with temperature and elevation.
  6. Feb 14, 2019 at 9:13 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    UPDATE 2/14/19:
    Quick little update. In regards to the tank and the incorrect fill hole, I have found a company local to me that is able to drill out the incorrect filling and spin weld a new 1-1/4" FPT fitting into the tank which will allow me to use the fittings that I already purchased and planned on using all along. It's an added expense but I got a steal on this tank so I'm not too worried.
    In addition to that, I purchased the last big item, my Tembo Tusk Jumbo Front Pull Slide. It's super pricey but I finally plan on having a drawer system for more than a year this time so I feel it's money well spent.
  7. Feb 20, 2019 at 7:09 AM
    Pyrotech
    Pyrotech Well-Known Member
    this is going to be epic
  8. Feb 20, 2019 at 10:13 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    You're damn right it will be!
    Pyrotech[QUOTED] likes this.
  9. Feb 20, 2019 at 10:18 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    UPDATE 2/20/19:
    I got my Tembo Tusk slide in the mail yesterday! that thing is an absolute beast! I'll get some pictures up tonight. Additionally, I got a new fitting installed on my water tank, they did a decent job but I am going to plastic weld over the fitting to clean it up and add a little extra security to the fitting. I'll post some before and after pics because they did a little bit of a hack job but I guess that's what I get for $10.
    At this point I have all of the major components and it's about time to just build the damn thing. I am going on a ski trip this weekend but hope to start building next week.
  10. Feb 21, 2019 at 11:17 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Try the water heater section at Lowes. They have plastic fittings that size
  11. Feb 22, 2019 at 6:25 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    I ended up getting it figured out! Thanks for the advice!
  12. Feb 25, 2019 at 7:46 AM
    dmurph1996
    dmurph1996 Beer me
    murph
    Arvada, CO
    2018 Tacoma TRD Offroad
  13. Feb 25, 2019 at 7:56 AM
    JamBar215
    JamBar215 Well-Known Member
    James
    2018 TRD OR DCLB
    Not enough
    Build looks like its going to be awesome! Going to have to see how this turns out.
  14. Feb 25, 2019 at 9:16 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Thanks!
    dmurph1996[QUOTED] likes this.
  15. Feb 25, 2019 at 9:17 AM
    #35
    upTOPOverland_Drew
    Drew
    Littleton, CO
    It's going a little slow at the moment but I'm working on CNC designs so I can have everything as precise as possible!
  16. Feb 25, 2019 at 9:25 AM
    #36
    JamBar215
    James
    2018 TRD OR DCLB
    Not enough
    Dang man, thats impressive. I'm a little jealous!
  17. Feb 28, 2019 at 6:17 PM
    #37
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Hey Drew,
    Would love to meet you in Denver to check this out in person!
  18. Feb 28, 2019 at 7:16 PM
    #38
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Let’s make it happen!
  19. Mar 2, 2019 at 11:34 AM
    #39
    Guardian
    Guardian Well-Known Member
    Colorado
    3rd Gen DC TRDOR
    Likewise, if you guys don't mind a third wheel. Also, I'd just like to meet up with some like minded CO peeps. I'm up in Loveland. Have you sold your V1 and V2 builds?
  20. Mar 2, 2019 at 2:38 PM
    #40
    upTOPOverland_Drew
    Drew
    Littleton, CO
    V1 got trashed after I pulled all the reusable hardware off and the V2 got sold to a member in the springs.
    But once I get rolling on this you are welcome to come down and check it out. I’ll be at some events in Denver too like RSGs open house and Toytecs customer appreciation day!
    The project is on hold for a few more weeks while I finish up on a few other things including a new roof rack
    raco.the.taco, Guardian and JoeCOVA like this.
