Dorman blend door actuator
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tmar04, Nov 15, 2024.
  1. Nov 15, 2024 at 6:59 PM
    Tmar04
    Tmar04 [OP] Well-Known Member
    Terry
    2004 Tacoma prerunner
    Anyone have a comment about Dorman blend door actuator. Mine is going south and I need to replace before cold weather arrives. Any comments, good or bad. Thanks to all.
  2. Nov 15, 2024 at 7:31 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Changed mine out a year ago. Still works.
  3. Nov 16, 2024 at 3:41 AM
    Tmar04
    Terry
    Thank you.
  4. Nov 16, 2024 at 12:26 PM
    dustytaco89
    dustytaco89 Active Member
    2004 Tacoma Prerunner
    Just bought one and waiting for it to arrive so I can install. Idk if that helps but I can let you know in a few weeks
  5. Nov 16, 2024 at 12:44 PM
    Tmar04
    Terry
    Same here. We’ll both know at same time. I’m sure it will last a few years
  6. Nov 16, 2024 at 12:57 PM
    dustytaco89
    Yeah I hope so!
  7. Nov 16, 2024 at 1:07 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Typically they (and most other parts store/aftermarket actuators) are junk but occasionally you get one that works for a while.
  8. Nov 16, 2024 at 2:07 PM
    dustytaco89
    For sure most aftermarket parts are a gamble. But I’ve had good luck with some and can’t afford OEM. Fingers crossed
  9. Nov 16, 2024 at 2:23 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Dorman makes a lot of different aftermarket parts, and this one seems to have a fairly decent rep. Check the price of the OEM part too and compare. It might be within reach without breaking the bank.
  10. Nov 16, 2024 at 2:31 PM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    when you hafta go chineseiem..Dorman is prolly a good option
  11. Nov 16, 2024 at 2:48 PM
    dustytaco89
    Good to know it has a decent rep and Dorman does too. Cheapest OEM I could find was $175.00 compared to $50 for Dorman. Easy choice for me for fairly non-important part (I live in the Bay Area in ca - mild weather).
  12. Nov 16, 2024 at 2:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Those of us that work in a shop and have to deal with their junk would tend to disagree, some of their hard parts are good but most stuff they make with an electrical connector is junk.
    I can't tell you how many of those aftermarket actuators I've had to warranty multiple times, not a huge deal if it's an easy one to replace but if it's a pain in the butt one or the dash has to come out it's getting OEM only but hey if it meets your needs and budget go for it, I'm just fed up with having to redo stuff constantly because of shit parts.
    It sucks that it's like this but the majority of aftermarket parts and even alot of OEM parts now are just China garbage made with low quality materials and zero quality control.
  13. Nov 16, 2024 at 3:33 PM
    Tmar04
    Terry
    I think these Dorman actuators are made in So Korea. That’s a notch above the Chinese junk
    Steves104x4 likes this.
  14. Nov 16, 2024 at 5:35 PM
    monkeyodeath
    monkeyodeath Well-Known Member
    Joshua
    Los Angeles
    2003 4x4 TRD
    I have a hard time believing that there are multiple factories making such a specialized part, and I wouldn't be surprised if the Dorman part is the same thing you'd get from the Toyota dealership. Crack one open and you'll see there's not much going on inside -- an electric motor and some plastic gears.
    For whatever it's worth, the part that usually goes bad on these is the little motor inside. GM part 25770692 uses the exact same little motor and you can get them for ~$20 on ebay.
    You've got to open up both actuators to swap the motor over (the GM part casing is different) but it's a lot cheaper than buying a whole new part, especially when the only part that actually goes bad is usually the motor.
  15. Nov 16, 2024 at 5:39 PM
    Tmar04
    Terry
    To further complicate things, I have seen 10-15 of these all Dorman with exact same part number 604-333 . About half say it fits my taco, and half says it won’t fit. Go figure.
  16. Nov 17, 2024 at 6:26 PM
    dustytaco89
    I had reas this somewhere on this forum I think. That’s a great idea since I’ve cracked mine open already and it would a simple swap. Thanks for the tip
