Dorman carrier bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tmar04, Oct 5, 2024.
  1. Oct 5, 2024 at 8:36 AM
    Tmar04
    Tmar04 [OP] Well-Known Member
    Terry
    2004 Tacoma prerunner
    Is Dorman carrier bearing an acceptable replacement for bad OEM on my 2000 prerunner? Or , are they like all rest of clones on market? Again, my thanks to you guys.
  2. Oct 5, 2024 at 8:47 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Go with Spicer instead of Dorman. I was able to get a Spicer carrier bearing on Amazon for like $65 or so a couple years ago. It came with the Toyota part number and all. Never heard of anyone running the Dorman option. Many run the Spicer option for years without problems though
    Old metals likes this.
  3. Oct 5, 2024 at 8:51 AM
    Tmar04
    Terry
    Thank you my friend. I’ll check Amazon
  4. Oct 5, 2024 at 10:09 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Using Toyota OEM for all running parts and their connections (engine, transmission, suspension, and drive train) will save you a lot of headaches.
    Black97v6MT likes this.
  5. Oct 5, 2024 at 10:30 AM
    Red_03Taco
    Jerad
  6. Oct 5, 2024 at 11:46 AM
    Tmar04
    Terry
    Thanks for tip. I purchased the Spicer bearing and bit the bullet!
    Red_03Taco likes this.
  7. Oct 5, 2024 at 3:51 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I went with an SKF (I think) a few years ago. 2 years later the rubber is blown the f*** out. Would steer away from anything other than OE or OEM, like others said I think Spicer is as close as you’ll get to a Toyota part
  8. Oct 5, 2024 at 3:56 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I think Spicer IS the OEM, last Spicer I bought came with Toyota stamped into the rubber
    Laxtoy likes this.
  9. Oct 7, 2024 at 12:12 PM
    phoforbreakfast
    phoforbreakfast Well-Known Member
    I ended up replacing the entire driveshaft with a remanufactured one and it comes with the carrier bearing already installed. I was planning to replace just the carrier bearing but I figured it'd be easier to just do the whole driveshaft instead so food for thought. I have an extra National HB-31 carrier bearing which I prefer over the Spicer since it's sealed like the OEM if you're interested.
  10. Oct 9, 2024 at 3:12 AM
    Tmar04
    Terry
    Thank you but I have already purchased spicer bearing.
  11. Oct 9, 2024 at 3:44 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I had that Spicer one on my last truck for 5 years/100k when I sold it. Still looked good and worked fine. I would get a new stake nut from Toyota though.
  12. Oct 9, 2024 at 5:13 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Yeppers
