Dorman Electrical Wire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Av8er, Sep 5, 2012.
  1. Sep 5, 2012 at 2:01 PM
    Av8er
    Av8er [OP] Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    Can anyone let me know if this wire (from AZ) is any good?
    http://www.autozone.com/autozone/ac...ical-wire/_/N-25r0?itemIdentifier=163451_0_0_
    They show two options for sale, this at $6.99 for 30', and Painless Wiring 50' for $19.99.
    Any advice on which if either is any good for wiring up some bed led lights. Need something sturdy as these are marketed as "extreme conditions" lol.
    Tks for any advice or any other options from other stores. (AZ is the closest ;)
  2. Sep 5, 2012 at 2:08 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    you could always just go get some higher gauge wire hanging on the shelf like around 10gauge that would probably work for you better 16 gauge is kinda small
  3. Sep 5, 2012 at 3:09 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    That's 16 gauge wire, you won't have a problem with the draw of current.... IMHO.
    ... Do use an appropriate size fuse though, as it depends on the wattage and the number of lamps used.
    Post pics when you're done. :D
  4. Sep 5, 2012 at 4:28 PM
    Av8er
    Taylor
    Tks guys, yea I've already done the calculations on the wire and figured out it would work fine for my low draw led lights. (And no doubt will have it fused as well) ;) Will definitely post pics post project too.
    My main question was more about finding a good quality outdoor and durable wire to use. Need something that will last a while and stand up to rough conditions outside the truck. Was hoping the AutoZone wire would suffice due to the close location. I have lowes and hd as well though. ;)
  5. Sep 5, 2012 at 4:34 PM
    Round II
    Round II Member #12005
    You will be fine with the Vato-zone wire AWG is the most important thing. I know you said you were good with the amp draw on the 16AWG but I would opt for #14 or even #12. I never run anything smaller than #12. I find that #16 just wants to coil back up while installing.
  6. Sep 5, 2012 at 4:39 PM
    Av8er
    Taylor
    Great, thanks for chiming in. Exactly the type of info I was looking for. I ran the numbers on both gauge (16 and 14) and figured either would work. However the coiling info is great info. I'll go with 14 or 12 at this point to avoid the frustrations with the 16. Just wanted to make sure folks haven't had problems with the "vato-zone" options.
    Tks bud-
  7. Sep 5, 2012 at 4:40 PM
    Large
    Large Red
    Use LEDs for bed lights, a 12" strip is only 1.5 watts and you could probably run the LEDs around the bed rail with the #16. #10 is way overkill, even #12 is overkill. 12 is rated for 30 amps or so.
  8. Sep 5, 2012 at 4:48 PM
    Av8er
    Taylor
    Tks bud, at this point I'm going with 16' waterproof flexible led strip lighting with an in cab illuminated switch, fused off the battery and grounded at the switch and lights, using probably 14 AWG wire. I have the LB so after doing some measuring I think the 16.4' strip will work perfect. ;)
  9. Sep 5, 2012 at 4:48 PM
    Round II
    Nah any auto parts brick and mortar store wiring will suffice. If you were to go with Painless its all about product name.;)
    Though I agree 100% that #12 is overkill for the amount of current thats being used I still would run #12.
  10. Sep 5, 2012 at 4:57 PM
    Av8er
    Taylor
    Gotcha, yea I figured the painless version was just marketing hype but wanted to confirm it with you guys first.
    I guess either gauge will work fine for my needs, it really comes down to which is easier to work with when winding it through the trucks tight spots.
  11. Sep 5, 2012 at 5:00 PM
    Round II
    Yea #14 is more than ample for your application, just depends on if you're willing to pony up a few more beans for #12. The price difference between the two is negligible, though I do understand some people are on a tight budget.
  12. Sep 5, 2012 at 5:00 PM
    Large
    Large Red
    You are right, I am a state licensed electrician and only run 12 in my truck. I did run 16 for strips in my tool box but that has since been removed and replaced by 12. Plus I get 500' rolls of it (dekoron brand) for $75
  13. Sep 5, 2012 at 5:04 PM
    Round II
    Nice I am as well been doing commercial and residential installations for 22 years, though now I just kinda sit in the office and pretend to work.:eek:
  14. Sep 5, 2012 at 5:16 PM
    Av8er
    Taylor
    That's why I love this site. Great feedback and advice from experienced (and licensed) members.
    Really appreciate ya'll taking the time to chime in. Looking forward to my first wiring project. ;) If I don't burn my truck down, I'll post pics. If I burn it down then you'll see me in the FS/WTB section. "WTB: Tacoma with bed lights already wired in." ;)
  15. Sep 5, 2012 at 5:18 PM
    Av8er
    Taylor
    Man that's amazing. $75 for 500'. Nice! At the cost of the wire at AZ, that'd work up to about $116 for the same roll (prior to any taxes/shipping).
  16. Sep 5, 2012 at 5:43 PM
    Av8er
    Taylor
    So my last question, with respect to the different gauges, should I be concerned with the length of run I'm planning? ie. battery to switch to rear of corner of longbed. ?? I'll probably go with #12 or #14 at this point (most likely 12) but I remember reading that longer runs can be a concern?
