Dos and don'ts of 30k mile service
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe O., Apr 20, 2022.
  1. Apr 20, 2022 at 12:21 PM
    Joe O.
    Joe O. [OP] Member
    Joe
    2020 access cab 6 foot bed Tacoma
    This is every service my Toyota dealership recommends at 30,000 miles (not including oil change.) What is and isn't necessary?
    -Reset maintenance reminder light
    -Clean battery cable ends and terminals
    -Perform brake fluid exchange service
    -Perform multi-point inspection
    -Replace cabin air filter
    -Install windshield washer solvent
    -Perform battery load test
    -Re-torque drive shaft flange bolts
    -Lubricate propeller shaft bushings
    -Lubricate drive shaft bushings
    -Wheel alignment
    -Install fuel system conditioner
    -Perform intake throttle body fuel injector service
    -Perform maximum engine performance service
    -Perform rear differential fluid exchange
    -Perform climate control service
    9th likes this.
  2. Apr 20, 2022 at 12:23 PM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    The items that are not listed for the 30K service in the owners manual are not necessary.
  3. Apr 20, 2022 at 12:24 PM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    I'd ask for a LOT more detail about:
    Are they charging you $90 to pour a bottle of Gumout in your gas tank?
    cammerv8 and JJ Diablo like this.
  4. Apr 20, 2022 at 12:26 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    too early for a brake fluid change, they go by time or than miles. At the earliest I'd change at 3 years mark, unless you live somewhere too humid then maybe change it at 2 years
  5. Apr 21, 2022 at 8:17 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Just follow whats in your owners manual unless there is a specific severe duty issue you need servicing. Dealerships love to pad their services with high profit extras that you really dont need. They love to say “its cheap insurance”… Its not.
    Chew likes this.
  6. Apr 21, 2022 at 8:30 AM
    Ob1-adobe
    Ob1-adobe Well-Known Member
    2019 Tacoma TRD Off-Road DCSB Magnetic Gray
    I just had my 25k service done and the 3rd brake light recall. This is next and will be the last time I get the free toyota care.
    I have to wait until the end of may to get the damn TSB on the serpentine belt done.
  7. Apr 21, 2022 at 9:34 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    This is how I see this list realistically…
    -Reset maintenance reminder light - Yes (this is a given and takes a minute)
    -Clean battery cable ends and terminals (if its corroded sure, it only takes a minute)
    -Perform brake fluid exchange service (brake fluid will realistically last a decade or more - not that you should wait that long, but virtually nobody does this at only 30K)
    -Perform multi-point inspection (whatever that’s supposed to mean… take a few minutes to look around the truck and engine bay for low fluids or loose things)
    -Replace cabin air filter - Yes
    -Install windshield washer solvent (only if it’s low, takes a minute)
    -Perform battery load test (only if the truck has been having issues starting)
    -Re-torque drive shaft flange bolts (can’t hurt to take a minute to check, but can’t say I’ve seen too many driveshafts fall apart from not checking the torque)
    -Lubricate propeller shaft bushings - Yes (every 15K)
    -Lubricate drive shaft bushings (redundant)
    -Wheel alignment (if the tread wear is uneven or the truck is pulling to the side, etc… otherwise do when you get new tires)
    -Install fuel system conditioner (totally unnecessary at 30K)
    -Perform intake throttle body fuel injector service (totally unnecessary at 30K)
    -Perform maximum engine performance service (fancy name for nothing)
    -Perform rear differential fluid exchange - Yes
    -Perform climate control service (only need to recharge A/C if it’s not as cold as it should be - basocally unheard of at 30K though)
    Kev250R, Chew, cammerv8 and 2 others like this.
  8. Apr 21, 2022 at 9:59 AM
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    Go in with an a la carte list of what you want them to do. Never ask for a "30k service" because they will add in a bunch of extra stuff.
    Even if you have them do the fluids, you can save about $64.95 by doing the cabin air filter yourself with a $10 OEM or Denso from Amazon. Same with the air filter.
  9. Apr 21, 2022 at 10:06 AM
    bush rat
    bush rat Well-Known Member
    BC
    2022 6MT Access Cab
    dealers are very good at suggestive selling on non warranty stuff.
    good that you are skeptical.
    many will fork out the $$$.
    Travace and Taco_mike73 like this.
  10. Apr 21, 2022 at 10:07 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The 30k service was the last dealership service for me, and the only one requiring payment (not included in the truck's sticker).
    It's strict by-the-manual from 30k on out. Its a great reference for those that don't know what's essential and what's bill-padding.
  11. Apr 21, 2022 at 10:09 AM
    JSmith501
    JSmith501 Well-Known Member
    San Antonio, TX
    2017 Off Road 4x4
    Interested in how humidity may affect... Isn't it a closed system? I live in Texas so we certainly see our fair share of humidity.
  12. Apr 21, 2022 at 10:27 AM
    malatx
    Purely speculating, I don't think the brake fluid is in a completely sealed system, imagine the thermal expansion the fluid can experience from being heated by the hot brake pistons, that pressure has to go somewhere. Plus the brake fluid reservoir cap can be opened and that introduces moisture from the air too
    I'm in central TX, last time I checked with one of those brake fluid test pens that reads water level, 3 years old fluid I got yellow warning, not too bad
  13. Apr 21, 2022 at 10:30 AM
    adrew
    Leer 100XR
    And it's hygroscopic (absorbs water). And water is heavier than brake fluid so it will inevitably settle to the lowest point of the system, the calipers or wheel cylinders.
  14. Apr 21, 2022 at 11:22 AM
    JSmith501
    San Antonio, TX
    2017 Off Road 4x4
    Interesting. I haven't changed my brake fluid yet (that i can recall), so i am gonna take a look.
    Thanks!
  15. Apr 21, 2022 at 12:40 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Toyota also sells the once a year alignment that I refused.
  16. Apr 21, 2022 at 1:29 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I do all my own maintenance and would do all minus those in red. There’s no zerk fittings on these later vehicles.
    -Wheel alignment
  17. Apr 21, 2022 at 1:40 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    Exactly my question on the propeller shaft and drive shaft. How to lubricate these when there are no visible zerk fittings?
  18. Apr 21, 2022 at 3:01 PM
    geo8866
    geo8866 Unknown
    2019 TRD Sport cement
    There are two zerks on 4WD models. (At least there are on 2019 models.) One is easy and one is a bitch to get to.
  19. Apr 21, 2022 at 5:51 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    They charge you, list it being done on the invoice, and you leave happy, comrade. You ask no questions...
    In all reality they charge you and do nothing
  20. Apr 21, 2022 at 5:54 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Where are you located Joe? If you happen to reside in the New England area I’d be happy to give you a hand. Before you know it you’ll become a seasoned DIY’r with all the experience you will find here.
