double battery wiring?
Discussion in '1st Gen. Tacomas (1995-2004)' started by OddSmurf1492, Aug 6, 2009.
  1. Aug 6, 2009 at 10:30 PM
    OddSmurf1492
    OddSmurf1492 [OP] Member
    MN
    99 2.4 5spd base
    how would you guys suggest doing wiring up a double battery set up?
    i have a basically brand new battery that came from my uncles ranger before the engine blew and was thinking of getting a battery tray and mounting it behind the air box. i plan on running a "few" lights and such hehe
    pos to pos/neg to neg?
    engine to pos of bat1, neg of bat1 to pos of bat2, neg of bat2 to original neg?
    what size wires?
    any fusing necessary?
  2. Aug 6, 2009 at 10:34 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    good question, I am subscribed to see the answer
  3. Aug 6, 2009 at 11:30 PM
    rblloyd
    rblloyd Member
    1999 2.7L SR5 Tacoma 4x4
    There are two ways to do it:
    One is to wire both batteries together in the fashion that you mentioned. This would create a series circuit. There are a few problems with this setup. One is that the batteries are constantly connected meaning if you run them down they will both run down together. Your spare battery can not be run down without running down your starter battery. Also, it can be hard on your alternator if both batteries are run down extremly low because it has to charge both at the same time. Often times two batteries in series will pull more amps than the alternator is made to deliver.
    The second (and better way) to do it is to buy a battery isolator that can be placed in between the batteries. It is a device that will connect the batteries to the alternator when the truck is running in order to charge them, but will disconnect them when the engine is shut off so that the spare battery can be used till it dies without running your starting battery down. This setup is often used in inverter setups and motorhomes.
    You should be able to purchase an isolator at any auto parts store or maybe an RV shop.
  4. Aug 6, 2009 at 11:46 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    It's actually called parallel wiring. Series would be positive to negative and would double the voltage to 24v.
  5. Aug 7, 2009 at 9:47 AM
    rblloyd
    rblloyd Member
    YA, im sorry i meant parallel... my bad.. Im used to working on CAT excavators and dozers that all run on 24v!
  6. Aug 7, 2009 at 9:58 AM
    thekidcatcher
    thekidcatcher Well-Known Member
    Waco, TX
    05 TRD offroad SR5
    Legs- --Helo rims --Duratrac 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    Check out 12voltguy.com he has a really good dual battety kit. :)
  7. Aug 7, 2009 at 10:04 AM
    OddSmurf1492
    MN
    99 2.4 5spd base
    What amperage is the alternator on the 2.4?
  8. Aug 7, 2009 at 11:07 AM
    johnecon2001
    Phoenix, AZ
    Gotta love finding accessories for that stuff :p
  9. Aug 7, 2009 at 12:04 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
  10. Aug 1, 2012 at 8:26 PM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    Great Find man! This is the most affordable setup I've seen :D
  11. Aug 1, 2012 at 8:32 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  12. Aug 3, 2012 at 6:25 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Agree, isolator the way to go. That way you can run the extras off the secondary battery and not have to worry that you've run your starting battery flat.
    Your stock alternator should be 70 amp on the 2.4 from what I can see.
  13. Aug 3, 2012 at 6:41 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
