Double Cab Long Box Suspension Lift - 3rd Gen
Discussion in 'Suspension' started by SRK_yota, Oct 18, 2021.
  1. Oct 18, 2021 at 5:19 PM
    SRK_yota
    SRK_yota [OP] New Member
    srk_yota
    2021 TRD Sport
    stock
    Looking for advice/direction from the true Tacoma Pros on TW regarding a suspension lift.
    I have a 21' TRD Sport Double Cab with a long box.
    The official word from Toyota Canada is that they "Don't Recommend the TRD Lift Kit for the DBLB" and that it could "possibily" effect the warranty (https://pressroom.toyota.com/step-up-new-tacoma-trd-lift-kit-now-available/ ). I have recently confirmed this over the phone with a customer service rep at head office.
    However, My dealership says that they can do it.?!
    I've asked around the local Tacoma groups here in Canada, but generally get mixed information. Everything ranging from "fuck the warranty. It's a Tacoma" and "use Bilstein 5100s for better bang for your buck."
    Also, received some sound info about the Rear end sag with the long box and the need for an extra leaf. Another comment about the rear drive shaft angles not working with a lift.
    I'm trying to get to the bottom of this. Ultimately, I'm looking to give my truck a few extra inches of clearance. Something equivalent to the TRD Lift - 2" front / 1" rear
    Is it possible with a TRD Sport DBLB. What do I need to get this done? Will it kill any part of my warranty?
  2. Oct 20, 2021 at 2:57 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Possibly maybe beacuse of the longer two-piece driveshaft?
  3. Oct 21, 2021 at 8:13 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    While the lift will technically work is it worth buying from Toyota if it doesn’t include the warranty? If it doesn’t include a warranty I would shop elsewhere. Either 5100, eibach, fox 2.0, bilstein 6112… The value in the factory kit is the warranty and warranty preservation.
    SRK_yota[OP] likes this.
  4. Oct 24, 2021 at 4:18 PM
    Rollo67
    Rollo67 Well-Known Member
    My 2018 DCLB TRDOR leaf packs went in like less than 40k miles (strange rear vibration at certain speeds). Granted, my normal GVW was 5340 lb. (2640 lb. front, 2700 lb. rear axles) but Toyota refused to warranty my leaf packs, even though my normal load was under max vehicle specs. Traced part of it down to tires but still have weird stuff going on in the rear axle. 3 dealers can't find anything wrong with the wheels or drivetrain. I'm about to install a Wheeler's Trail-Pro kit (Bilstein 6112/5160 shocks w/AllPro expedition leaf packs) and JBA UCA's. Will report back after the install what changes (if anything). What could possibly go wro....
    71tattooguy likes this.
  5. Oct 25, 2021 at 8:33 AM
    SRK_yota
    srk_yota
    2021 TRD Sport
    stock
    @Rollo67 - This is the kind of information I was looking for. Thanks for this. I live in Southern Ontario and have called all dealerships within a stones throw and not one will do the work. I need to find an experienced Tacoma Off Road shop familiar with the possible issues like you've stated. I've been told a subtle rear vibration is common and would like to avoid that with the right gear and mechanic. Thanks for the info and report back if you get the chance.
    19Canuck and Rollo67 like this.
  6. Oct 30, 2021 at 8:36 AM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Get yourself over here...... https://www.tacomaworld.com/threads/ontario-bs-thread.249665/
    Lots of info over there and in your location (or close to it) I have a simple 3/2 spacer/block lift. I run 5100's on the rear which handles the extra travel. I'm currently shopping for UCA's and a coilover set up for the front that will help me keep my 3 inch lift.
  7. Oct 31, 2021 at 12:18 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    It doesn’t matter what brand lift you get. You will either get some vibration or none. Each truck acts differently. Some guys go 3/2 on the lift and never have an issue and some may go 2/1 and chase one forever. Unfortunately it’s the nature of the beast.
