Double Cab + Manual Trans?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DCAlbarran, Mar 4, 2010.
  1. Mar 4, 2010 at 8:59 PM
    DCAlbarran
    DCAlbarran [OP] Active Member
    Hi there.New to the site, and looking for a first gen double cab in a stick. I did a search and didn't find anything. Does anyone know if these unicorns actualy exist? Thanks!
    -Danny
  2. Mar 4, 2010 at 9:00 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
  3. Mar 4, 2010 at 9:03 PM
    DCAlbarran
    Drag. Thanks.
  4. Mar 5, 2010 at 1:29 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    I was in the same boat as your a few years ago when I wanted a 5spd DoubleCab. I knew I wanted a DoubleCab, but had always had 5spds and looked for a while before I found out they don't exist. Only Automatics in the 1st gen DoubleCabs. I've always thought about retrofitting one though, I think that would be pretty sweet. Although, I have come to really like my A/T and not shifting gears all the time in city traffic. I do still miss it, though.
  5. Mar 6, 2010 at 7:29 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ive seen one. The only ones you will find are ones custom ordered and are very very rare.
  6. Mar 6, 2010 at 7:55 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i think its only 2wd 4 banger
  7. Mar 6, 2010 at 8:20 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    Funny thing is i told my wife this morning that i want to do this swap when i re enlist this year, and i will.
    As far as retrofitting, i have done this swap with a few cars, AE86 SR5 to a GTS, 85 Toyota Cressida auto to a 7MGTE + R154 5 spd to name the toyotas. You will need:
    Trans that bolts up, obviously those are available
    Driveshaft (if and only if a manual trans and auto trans have different lengths, i do not know at the moment if they are)
    5 speed pedal assembly
    Clutch line (or bend your own with a bender, pretty easy just take your time)
    Clutch master cylinder
    I believe thats it and you can get these very easily from a single donor vehicle, ie a wrecked tacoma. You MAY need a trans support, but maybe not, depends on trans length and location of the holes for bolts.
    I would also recommend changing the clutch, pressure plate, rear main seal, and slave cylinder while you are already there. It seems like a lot but it really isnt that much if you are decent with tools. There should already be holes lined up on the firewall for the pedal assembly and master cylinder. If anyone does this before i do, please do a write up, as i plan to do a pic by pic write up when i do mine.
  8. Mar 6, 2010 at 8:22 AM
    DCAlbarran
    Yeah, I dont have a Taco yet, but I imagine if and when the tranny gave out it wouldnt be too hard. Just thought maybe they were out there from the factory
  9. Mar 6, 2010 at 9:49 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The original detailed (and illustrated) writeup on this conversion was posted out on Junglecode years ago. That documentation went MIA some time back. I salvaged the materials and reconstructed the writeup as an archive over on CustomTacos:
    http://www.customtacos.com/forum/showthread.php?t=137151
    There are also multiple threads on this conversion to be found over at Tacoma Territory.
  10. Mar 7, 2010 at 7:50 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Is it difficult to do? Or does the 5spd just bolt in?
  11. Mar 7, 2010 at 8:08 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Read the documentation I referenced in the post immediately before yours and judge for yourself ...
