Double cab manual transmission swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by raimundough, Sep 12, 2019.
  1. Nov 15, 2019 at 12:57 PM
    #61
    Floridaze
    Floridaze Well-Known Member
    Pensacola
    97 ext cab 4wd
    Abs delete, lspv delete, led headlights, 5 speed swap, ome 882 nitrochargers and dakars
    The only thing that I worry about is the signal strength you’re getting from the flanges. They aren’t machined surfaces, which could cause irregularities in the signal from pulse to pulse. A mag pickup like that needs a set depth from the face of the sensor to the edge of the rotating surface to make the proper a/c voltage. Not saying that it has to be perfect but a feeler gauge and a file would go a long way in making sure that you’re getting a good signal
  2. Nov 15, 2019 at 1:04 PM
    #62
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    You are correct about mag sensors like that in general, but in this case we don't care about the irregularities, just as long as there are enough pulses to keep the ecu happy code wise.
    Normally these sensors would be mounted in a housing that would not move in relation to the rotor much, but in this case there could be a slight flex so this is more of a as close as you can get it scenario.
    Running man, its triggering off the rounded part of the driveshaft flange right underneath the stud/nut (there are 4 rounded parts). you could do it off the nuts, but since when tightened the heads may be at different angles you would have more irregularities in the signal.
    If this didn't work, I would have made a slip in metal wheel a few mm thick that goes between the flanges and has larger teeth like inside the trans, but since this worked and I have other projects, I am going to call it good enough for now.
    If you want to see what I am saying visually its basically like a crank trigger wheel, which there are plenty of examples on the internet.
    Running Board Man likes this.
  3. Nov 15, 2019 at 1:10 PM
    #63
    2JHilux
    Denver, CO
    everyone likes pics right?
    got a hilux leather shift knob and samurai transfer case shifter on, looks alot better.
    Why are the toyota transfer case knobs so boring looking?!?
    dmK7umu21IK1PdxDOpRzACW9IdtTum4MyYtIAfK8_e0db9df106bfb17d5a6413c26f239c09cb7a09ed.jpg
    goldentaco03 and cruiserguy like this.
  4. Nov 15, 2019 at 1:37 PM
    #64
    Floridaze
    Pensacola
    97 ext cab 4wd
    Ooh nice. I need a cup holder like that
  5. Nov 20, 2019 at 3:36 PM
    #65
    2JHilux
    Denver, CO
    Just wanted to update, still haven't been on the highway but drove the truck around a bunch and no codes at all, not even pending.
    Also it seems that cruise control works just fine, and even cancels when you push in the clutch a little if you wire up both clutch switches.
    Just be in the right gear before you set it and it seems to work, pretty much how it works in other manual cars.
    Malek likes this.
  6. Nov 24, 2019 at 4:43 AM
    #66
    Floridaze
    Pensacola
    97 ext cab 4wd
    Success! Yesterday got around to building a bracket for the speed sensor and extending the harness. Drove about 50 miles and no CEL so far. Thanks for the help 2JHilux!
    2JHilux likes this.
  7. Jan 20, 2020 at 12:06 PM
    #67
    Kkrause09
    Kkrause09 Well-Known Member
    Kyle
    Tacoma sas
    New here and need help to determine what I need to do to get truck started. 2002 manual swap about to take place but before I tear out auto I’m trying to figure what I need to do to the auto harness as I’m gonna run the auto ecu! Here is my plug to tranny, which wires do I connect or ground? I have no clue lol helppplpp
  8. Jan 20, 2020 at 12:10 PM
    #68
    Kkrause09
    Kyle
    Tacoma sas
    Clutch master installed and pedal
  9. Jan 20, 2020 at 1:44 PM
    #69
    Kkrause09
    Kyle
    Tacoma sas
    I figured it out thanks for the write ups I just had to read slowwwly
  10. Jan 21, 2020 at 9:58 AM
    #70
    2JHilux
    Denver, CO
    Passenger drop... sas? nice looking setup!
    I just wanted to update on the last stuff I wrote for rigging up the second VSS to get around the last code.
    I found that it would work fine in the city, but when I hit the highway depending on how I drove it would throw a code for gear ratio not matching.
    Basically you have to drive it like its an auto, if you are going to downshift then get on the throttle... like you would on an auto.
    So if you get on the throttle alot without downshifting (where ecu/trans thinks it should have downshifted), or downshift without getting on the throttle (ecu/trans thinks you didn't downshifting),
    it will trip the code and after 2 trips it will light the CEL.
    It's annoying, but if you drive it like an auto then the ecu won't pickup on the gear mismatch thing, and this only happened on the highway.
    I got tired of dealing with it and found a manual 5vz ecu from a tundra, and have been running that with no codes at all for a bit now.
    I would have gotten a tacoma ecu, but everyone wants like $400 for those. what happened to toyota love??? that is a big rip off for an old ecu.
    Running Board Man and Kkrause09 like this.
  11. Jan 25, 2020 at 1:47 PM
    #71
    cbass1
    cbass1 New Member
    2003 black Tacoma TRD
    In AZ too:(
  12. Feb 27, 2020 at 3:14 PM
    #72
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    How does one find wiring diagrams specific to the Tundra or different Tacoma years in order to see if the truck harness needs to be repinned?
  13. Feb 27, 2020 at 3:25 PM
    #73
    Running Board Man
    Running Board Man Well-Known Member
    Factory service manual
  14. Feb 27, 2020 at 3:25 PM
    #74
    Floridaze
    Pensacola
    97 ext cab 4wd
    Your best bet would be a factory service manual
  15. Feb 27, 2020 at 3:25 PM
    #75
    Floridaze
    Pensacola
    97 ext cab 4wd
    Haha, you beat me to it running board
  16. Feb 27, 2020 at 3:50 PM
    #76
    JasonLee
    15 TRD OffRoad
    How can I confirm the service manual I have actually matches my ECU and such?
    …besides comparing every pin on the wiring diagram to what is physically connected on my truck?
    I don't see the ECU/ECM part numbers in the service manual to confirm the same parts.
  17. Feb 27, 2020 at 4:48 PM
    #77
    Running Board Man
    http://www.well.com/user/mosk/images/Early_Tacoma_ECUs_v2.pdf
    2 google searches
  18. Feb 27, 2020 at 5:10 PM
    #78
    JasonLee
    15 TRD OffRoad
    Still doesn't answer my question. This PDF you linked (which I have) and the FSM don't show the ECM part/model numbers, so I can't just order one online knowing what the wiring/pinouts are.
  19. Mar 9, 2020 at 10:07 AM
    #79
    2JHilux
    Denver, CO
    You have to go off the number and shape of the ecu plugs as they change from year to year.
    If you can stay in the same year range it is more likely to match unless it was a year where they transitioned.
    Running Board Man and JasonLee like this.
  20. Mar 9, 2020 at 10:46 AM
    #80
    Running Board Man
    You could go to toyota parts deal enter a year make and model of truck ask to buy an ecu and theres the part number for the truck you imput
