Double cab manual transmission swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by raimundough, Sep 12, 2019.
  1. Mar 9, 2020 at 3:58 PM
    #81
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
  2. Mar 9, 2020 at 9:25 PM
    #82
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  3. Mar 10, 2020 at 12:52 AM
    #83
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    What cross member is that?
  4. Mar 10, 2020 at 3:35 AM
    #84
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You should try toyodiy.com first.
    Running Board Man likes this.
  5. Mar 10, 2020 at 7:35 AM
    #85
    Running Board Man
    Running Board Man Well-Known Member
    This website is awsome
  6. Apr 15, 2022 at 9:01 PM
    #86
    GaryV-01DC
    GaryV-01DC Member
    2001 Toyota Tacoma 4wd DC
    Hello all my 1st post here.
    I have a 2001 Double Cab Trd 4wd that I am wanting to manual swap.
    I have a complete 1999 Toyota Tacoma 4wd extended cab trd also with only 119xxx miles. (Rusted out frame) that I was wanting to use as a donor if I could.
    Is it possible for me to use the engine, transmission and complete wiring harness along with the ECU out of the 99 into my 01?
  7. Apr 20, 2022 at 6:50 AM
    #87
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    No. You can probably use the engine and transmission. Wiring harness and ECU will be different. Toyota in all of their infinite wisdom did a different pin out on just about every year Tacoma. The parts truck would also be good for the pedal assy, crossmembers (assuming that they're not rusted), clutch lines, master and slave cylinders.
    GaryV-01DC[QUOTED] likes this.
  8. Apr 20, 2022 at 6:58 AM
    #88
    GaryV-01DC
    GaryV-01DC Member
    What if I were to use the 99's (engine/ transmission) wiring harness plus the harness from the dash (also from 99) and swap them into the 01 along with the manual transmission ecu from the 99?
    I know that would be a lot more work but then I could carry everything over (clutch cancel switch, rear locker) including the gauge cluster
  9. Apr 20, 2022 at 8:25 AM
    #89
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    You could, hypothetically do that. You'll also need to swap the door panels to the older design and swap out the internals. It would be much better IMO to find a harness and ECU for a 2001 V6 Manual. That way, you can maintain the updated door cards/dash design. The other thing I've seen is that folks use the same automatic harness and plug it in to the manual ECU (for the same year truck). I think a wire or two needs to be moved, and you'll want to cap off the un-used transmission plugs.
  10. Apr 20, 2022 at 9:29 AM
    #90
    GaryV-01DC
    GaryV-01DC Member
    I think I'm just going to look for a harness for an 01 and 01 ecu that away I pretty much just plug it in and maybe just have to unhook some wires that were auto specific going to the gauge cluster.
    Thanks
    jacobrippey[QUOTED] likes this.
  11. Mar 16, 2025 at 6:28 PM
    #91
    idahohounds92
    idahohounds92 Hounddogger
    N. Idaho
    1999 Tacoma 4x4 extra cab 3.4l
    Could you post a link to the fitting and line you're talking about for the clutch line please?
