Double cab pillar removal?
Discussion in 'Audio & Video' started by SilverStreak05, Mar 23, 2010.
  1. Mar 23, 2010 at 8:13 PM
    SilverStreak05
    SilverStreak05 [OP] Well-Known Member
    NorCal
    2005 4x4 TRD Off-Road
    DR coilovers, DR rear reservoir shocks, Deaver custom 11 pack leaf springs
    Anyone know how to remove the front and rear pillars? The ones that house the seat belts.
  2. Mar 23, 2010 at 8:21 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    They are part of the structure of the cab. I am sure you can remove the molding and take the spot welds out to replace them only after some serious bracing and welding. As for taking them out all together I would think you would have to do some outrageous custom fab work. Overall I think a shop should do it to ensure the safety and integrity of the cab are not compromised.
    If you are just looking to expose them down to bare metal then all you have to do is take the seat belts off and a few bolt then you can remove the molding, it just pulls away.
  3. Mar 23, 2010 at 8:59 PM
    SilverStreak05
    NorCal
    LoL, yeah man I was just talking about the interior panels. I guess I should have been more specific.
  4. Mar 23, 2010 at 9:07 PM
    JJ Customs
    Jay
    NV
    Good deal man, you had me a little worried! First you need to take the trim piece off at the door sill (little flat plastic at the bottom). then pull the trim piece off of your seat belt then you will find a couple random little screws, take them out and work the panel off. Pull lightly and you will be fine. When you put it all back together make sure you torque the seat belt bolts back down and you will be good.
  5. Dec 12, 2012 at 2:02 PM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Yea just finished this, thought i could add some to help. For the inside trim on the "B" pillar, this is between the font and rear seats, where your seatbelts go into for the front seats.
    remove trim pieces at the bottom of door sills, grey, flat pieces both doors. just pull up and they will pop out.
    remove the door gasket on the side you are working on just start at the bottom and carefully pull it out until it is clear of where you are working
    Remove the cap over the seatbelt bolt on the bottom. Pry the top edges open and pull it off.
    remove the seatbelt bolt at the bottom, 14mm
    Pull the lower trim piece off, straight into the car, move the front seat forward and lean it forward.
    remove the two 10mm screws at the base of the upper trim piece
    This is the crappy part, pull the bottom part outwards, and shove the top part forward to slide it from its button clip.
    to re-install do the opposite. however i recommend cutting off that top red snap button and getting a new one so you can put the snap on the trim piece first, then push the top of the trim piece straight on. You can slide it back on but it might screw up your headliner/ be a real pain / need four hands, a flashlight and a long handled screwdriver (this was the method i used)
    Running any wires into the headliner be careful to thread them behind your side curtain air bag!!! dont want anything getting between it, and you!.
    CaptSourPatch and Biscuits like this.
  6. Jun 2, 2021 at 7:41 PM
    Cam1106
    Cam1106 Member
    Camden
    Gray 2014 trd-off road
    Nothing currently
    Anyone know where you can buy the red tabs? I’ve been trying for hours and can’t get it back on...
  7. Jun 2, 2021 at 9:18 PM
    pochoboy
    pochoboy Well-Known Member
    sometimes youtube can be a very helpful resource
