double cab rear door panel removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by ParkerMcCombs, Apr 7, 2016.
  1. Apr 7, 2016 at 9:34 PM
    ParkerMcCombs
    ParkerMcCombs [OP] New Member
    Parker
    Reno, NV
    2008 DCSB
    Hey can anybody help me out with removing my rear door panels? I've worked at them but there is something I'm missing. Thanks.
  2. Mar 21, 2020 at 7:22 AM
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    Hi, I didn't want to create another thread, please help it seems that the lock handle (inside) is still attach by something after removing the screw. Rear door.
    2002 DC
  3. Mar 21, 2020 at 3:19 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    From the FSM.
  4. Mar 21, 2020 at 4:29 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Hey, when you undo the rear screw in the handle, you then slide it forward (towards the interior of the car) it is still clipped in sorta. Then it will pop out. Then you pull up the padding on the arm rest and there are the two screws in there. Then pull from the bottom corners to pop off the plastic clips.
    edit: you need to turn the door handle sideways after you get it popped out of place, for the door to come all the way off, and don't forget to undo the wire for the window.
  5. Mar 21, 2020 at 4:50 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Here's the front and back sides of a rear door panel. Note the position of the screws for the armrest and all the retainers that pop out by pulling or carefully levering them straight off. The panel lifts up to remove it, with the window channel the last piece to disengage.
    Click on any photo to enlarge.
    Here's a rear door with the panel removed. Note the positions of the retainers and the speaker/power window-lock harnesses. The door release rod is visible, too.
